WW2 or bigger turbo for 2001 7.3 ? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 29 Old 04-07-2014, 08:37 AM Thread Starter
jakethesnake1990's Avatar
Right now I have stage 1 injectors, pillar guages, jasper rear,4.56 gears, tony wild man tunes, air dog 2, when I bought the truck it had a different hpop but which one i dont know. The problem im having is trying to keep my egts low. Will WW2 lower egts much ? How much hp will a WW2 or bigger turbo add.
2001 F250 7.3
8 inch lift on 37s
6 Pos ts tony wildman tunes
Pillar gauges
4.56 gears
jasper rear
Stage 1 injectors
Silverline exhaust
Violant intake
Viper keyless start
jakethesnake1990 is offline
post #2 of 29 Old 04-07-2014, 08:54 AM
Joel's Avatar
Quoted: 10 Post(s)
It won't lower them much. Buts it's still a great upgrade.
You don't have a crazy set up or anything. EGT's shouldn't be an issue.
What do you have for intake and exhaust?
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 29 Old 04-07-2014, 10:55 AM
RPM Tim's Avatar
Short answer, no. Under what conditions and in what tune are you seeing high temps, &how high? As Joel said, exhaust?
2002
250 CCSB 4x4 7.3
stock~ diy B085011 / DEP 5" Turbo Back w/muffler / Phoenix chip
RPM Tim is offline
post #4 of 29 Old 04-07-2014, 11:14 AM Thread Starter
I think Its called like a silver line exhaust, i think it's 4 inches. Intake is violant. And it does it when i have the pedal to the floor. One time in the "street" tune i was going about 70 mph, i look over at the guage and it's 1500+ degrees. I'm also trying to figure out why the truck shuts off when coming to a stop but that's on my other post.
2001 F250 7.3
8 inch lift on 37s
Pillar gauges
4.56 gears
jasper rear
Stage 1 injectors
Silverline exhaust
Violant intake
Viper keyless start
post #5 of 29 Old 04-07-2014, 11:15 AM Thread Starter
I want to take the muffler off because that should lower it some
2001 F250 7.3
8 inch lift on 37s
Pillar gauges
4.56 gears
jasper rear
Stage 1 injectors
Silverline exhaust
Violant intake
Viper keyless start
post #6 of 29 Old 04-07-2014, 01:22 PM Thread Starter
Im in the truck now and from 0 to 60 on stock with no tunerbit goes over 1300
2001 F250 7.3
8 inch lift on 37s
Pillar gauges
4.56 gears
jasper rear
Stage 1 injectors
Silverline exhaust
Violant intake
Viper keyless start
post #7 of 29 Old 04-07-2014, 01:31 PM
dannanw's Avatar
Quoted: 66 Post(s)
Garage
sounds like you've got a bigger hpop...do you know what your tunes are? if they're not for bigger hpop/bigger inj's then I'd get that fixed. hows the turbo look (I/E what contidion is it)? Also what kind of boost numbers? If no guage(s) I'd start there. look for boost leaks...
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #8 of 29 Old 04-07-2014, 01:49 PM Thread Starter
Boost at 60mph was around 15
2001 F250 7.3
8 inch lift on 37s
Pillar gauges
4.56 gears
jasper rear
Stage 1 injectors
Silverline exhaust
Violant intake
Viper keyless start
post #9 of 29 Old 04-07-2014, 03:56 PM Thread Starter
My tunes were tuned for everything I have on the truck injectors,hpop, etc. Will a wicked wheel give me better throttle response ?
2001 F250 7.3
8 inch lift on 37s
Pillar gauges
4.56 gears
jasper rear
Stage 1 injectors
Silverline exhaust
Violant intake
Viper keyless start
post #10 of 29 Old 04-07-2014, 04:59 PM
Joel's Avatar
Quoted: 10 Post(s)
Your boost is WAY low.
At full throttle you should be making around 30.
Joel is offline
