Lift kit opinions ? - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By scagle1
post #1 of 9 Old 04-04-2014, 03:13 PM Thread Starter
Lift kit opinions ?
Wanting a 4" maybe 6" suspension lift . What brand does everyone like the most ? F250 2000 with 7.3 .
Mike/2000 is offline
post #2 of 9 Old 04-04-2014, 03:20 PM
RAMKILLER97's Avatar
I have a pro comp on my truck, 6 inch for an excursion but its a 4 inch for a regular 250/350. I have had it on for about 2 years now and have had no issues with it.
2003 Excursion Eddie Bauer 7.3
6 Inch ProComp Lift, 315/75/16 BFGoodrich All Terrain Tires, BTS Transmission, 175/100 P.I.S. Injectors, PMF Traction Bars, Garrett 38r, International Up Pipes, Dyno Proven Tunes, 6.0 Transmission Cooler, CCV mod, MBRP 4" Turbo-Back Exhaust, RiffRaff Over Boost Code Regulator, Moto Metal MO951 Black Rims, Dual Sky Jacker Steering Stabilizers, GlowShift Gauges, Mile Marker 449SS Lockout Hubs, 6637 Intake.
Putting this old PMR truck to the test....
RAMKILLER97 is offline
post #3 of 9 Old 04-04-2014, 03:24 PM Thread Starter
Cool thanks will check them out . Does it also ride nice ?
post #4 of 9 Old 04-04-2014, 03:32 PM
Yea I mean it rides better I think than it did stock. I also have air ride in the back so its stiff if I inflate that too.
post #5 of 9 Old 04-04-2014, 07:54 PM
What air ride do you have I Pam on getting this sometime in the future
E99 F250 XLT SuperCab 4x4 3.73 gears, 213k and climbing, ZF6 trans w/ 1944-60K SB Clutch/Flywheel, 6637 filter, muffler/cat delete w/ 5 inch tip, PHP Hydra, 4 gauge pod(EGT, EOT, FUEL PSI, BOOST), 12000 lb Warn Winch, 07 headlights/grill, 6k HID kit, Bushwhacker pocket style fender flares, Pioneer 7" touchscreen, 2.5 inch leveling kit with 315/75/16 General AT2s on stock 16 bullets, HPX
Next up: Rebuild Kit and Billet Wheel, Fixing E-brake so I can park on hills!
Tow51Stang is offline
post #6 of 9 Old 04-05-2014, 07:23 AM
It's an Air Lift. It was on the truck when I got it. Looks simple to install, and the nipples for putting air in come out my rear license plate so it's pretty discrete.
post #7 of 9 Old 04-05-2014, 01:31 PM
scagle1's Avatar
I have a 4" pro comp and think it rides hard as well as looking like the front springs have some sag in them. I had an 01 I put a 6" Rough Country on and it rode way nicer than this one and the factory ride setup. I have the fireatone ride rite setup , seems to ride the same whether I leave it empty or up around 20psi. Could go higher PSI but it's just going to make it stiffer.
RedneckYankee likes this.
Sold 01 350 6" on 37's and mild mods, 00 X 4" on 35's, 02 f350 4" 35's modded from fan to drive shaft, ridin the 03 with nose conversion with 125k and counting upwards slowly.
Never had CNC's poo on any of it, never will.
scagle1 is offline
post #8 of 9 Old 04-06-2014, 04:59 PM
DIMBLEWAMBIE's Avatar
I have Deaver springs and they are a damn good ride compared to my buddies Fabtech lift.. 8in.
What size tire are you wanting to run on your truck?
Justin DIMBLEWAMBIE Lamb
2002 F250 7.3l 4x4 CCLB
8in lift Deaver springs, Bilstein 5125s & 5160s
Toyo 37x13.50r17 MTs, Eagle Alloy 185s
F8 Destiny DP-Tuner & Dyno Proven
Banks Boost, EGT, Trans gauges
Banks straight pipe, K&N intake w/ 6637 filter
Banks EBPV-less elbow, Wastegate ON [OFF]
Foil delete mod, Zoodad mod
11" LED bar, 05-07 grill
DIMBLEWAMBIE is offline
post #9 of 9 Old 04-07-2014, 11:02 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
The best riding lift kits for the 99-04 trucks hands down is Icon. We are a dealer PM me if I can help.
CT Performance, Inc. is offline
