oem steel rods what hp are they good to? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-03-2014, 11:04 AM Thread Starter
corn binder's Avatar
Quoted: 2 Post(s)
building a short block for my 01 7.3. I'm using a 96-97 engine, I'm gonna girdle, stud& balance the bottom end. the engine will be around 550 h.p. will the stock steel rods hold up?
99 f250 4x4 7.3 php tunes,20's
01 4x4 cc srw 7.3 550hp BTS trans
02 excursion LMTD 4x4 7.3
95mustang gt,86 5.0,03 gt
allis chalmers 185-d
corn binder is offline
post #2 of 8 Old 04-03-2014, 01:00 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Are they Forged or PMR?
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 8 Old 04-03-2014, 01:43 PM Thread Starter
Quoted: 2 Post(s)
all stock 7.3 rods are forged up til early 2000-ish. so yes forged
post #4 of 8 Old 04-03-2014, 01:48 PM
schlutzer's Avatar
Quoted: 18 Post(s)
You said its an 01 in your first post. Just wanted yo be clear which rods you were using
Then you *should* be okay at 550. But at the kind of power nothing is really safe. Some guys get them cryo'd
The Following User Says Thank You to schlutzer For This Useful Post:
Corey@CNCFAB (04-06-2014)
post #5 of 8 Old 04-06-2014, 06:31 PM
Quoted: 725 Post(s)
Make sure you machine the main caps all flat and line bore if your gonna put a crank girdle on it. Line bore isnt absolutely necessary, but depends on which one you go with.
Corey@CNCFAB is offline
post #6 of 8 Old 04-07-2014, 08:36 AM
joeyd61's Avatar
I am running 600-650 on factory forged rods.The mains were line bored but no girdle. Keep in mind my truck is not abused (often)..
[/SIGPIC]2003 Lariat, forged rod motor,BG S468 turbo,Terminator Twins HPOP,FF 300/200 injectors, air dog 150,walbro fuel pump,SD full regulated fuel return, Isspro EV2 gauges,BTS trans,4.56 Yukon gears,Iron Bull bumpers. Armed with Infinity, and on and on and on
joeyd61 is offline
post #7 of 8 Old 04-07-2014, 09:11 AM Thread Starter
Quoted: 2 Post(s)
That's good info to know, I wasn't aware needing to be line bored & machining of caps for a girdle.
post #8 of 8 Old 04-07-2014, 09:18 AM
Quoted: 725 Post(s)
There are two types of girdles. One is just a plate that gets bolted to the caps. The other is a whole big billet piece that replaces the caps. Hypermax.
The caps you would think are all exactly the same height but they are not always. So you have to take a known true machinist straight edge and ckeck. If not and you bolt done a plate girdle it will distort the caps and wipe out your bearings in a hurry.
