Can't remove bullydog..help - Ford Powerstroke Diesel Forum
post #1 of 14 Old 03-31-2014, 05:16 PM Thread Starter
I have a slight problem- When I bought the truck it came with a POS bullydog gt tuner. I finally got around to ordering the hydra chip from PHP, and went to sell the bullydog.
When going through the uninstall process on the bullydog, it requires you midway through to switch the key to the run position from the off position. In my truck when this happens, the OBD port loses power for a split second causing the process to start all over again. Basically, I can't uninstall this chitty bullydog and now have a pissed buyer.
Can I overlap my PHP chip while the bullydog is still installed on my PCM?
Its not plugged in, but the truck is still tuned. Any way to remove it from the pcm with a reflash or overwrite file?
Any advice/ help appreciated..
2000 7.3 f350 4x4 zf6
iThrowrods is offline
post #2 of 14 Old 03-31-2014, 10:51 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
the chip from php will over ride whatever is on the pcm. so you should be fine just hook the chip up and go
blue99stroker is offline
post #3 of 14 Old 04-01-2014, 01:16 AM
Rodslinger's B1TCH
you could try tapping a 12 volt constant power wire temporarily into pin 16 to keep the bullydog alive for the process. maybe check to make sure you're actually getting 12 volts there and your fuse isn't blown. maybe the bullydog only uses the 5 volt power pins?
steve604 is offline
post #4 of 14 Old 04-01-2014, 05:44 AM
PSD POWER007's Avatar
Quoted: 8 Post(s)
Send a message via AIM to PSD POWER007
Isn't the bully dog a piggy back tuner like edge and banks? It's just a matter of unplugging it isn't it??
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, DP-Tuner F6 Live tuned, 05 Harley's w/ HID conversion, Edge Insight CS, Dieselsite BRV & coolant filter, Factory 20" wheels, RiffRaff boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #5 of 14 Old 04-01-2014, 08:47 AM
LOTTS73's Avatar
To wipe it clean I had to have the computer flashed at the dealer. I do not know if your new chip will override
01 F-350 7.3 Auto/6637 mod/Muffler delete/Pillar gauges
LOTTS73 is offline
post #6 of 14 Old 04-01-2014, 11:09 AM
Rodslinger's B1TCH
for the edge you have to go through a process to remove the programming from the PCM and return to the stock set up it has stored in the module. i imagine that the bullydog works the same way.
to program your truck with one of these, you plug it in, got through a 5 minute process and then unplug it. every time you want to change settings you have to go through the process again. this is why the switchable chips became so popular instead.
steve604 is offline
post #7 of 14 Old 04-01-2014, 03:09 PM
Quoted: 8 Post(s)
Oh...I breifly ran an Edge on my 6.0 and Duramax...it had its own box that plugged up I between the PCM and the engine harness. I thought the bully dog was the same way. Didn't know it actually flashed the PCM.
post #8 of 14 Old 04-01-2014, 05:23 PM Thread Starter
Sadly not a piggyback tune. How much will a computer reflash at the dealer usually run? Seems like my best bet now that my PHP chip came in the mail today.
post #9 of 14 Old 04-01-2014, 06:36 PM
Quoted: 8 Post(s)
No need to worry about the stock PCM flash right now. The Hydra won't care about it. You can deal with a reflash whenever it's convienent for you.
post #10 of 14 Old 04-01-2014, 10:10 PM
Rodslinger's B1TCH
I would tap 12 volts into the wire to pin 16 to remove the bullydog tuning. This way you won't need to pay for a reflash amd you can sell the bullydog
steve604 is offline
