gauge locations? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-29-2014, 10:59 AM Thread Starter
gauge locations?
Just bought a 4 gauge pillar with boost, egt, eot, and fuel pressure. Where do I tap in for all of these? What should my readings be? My truck is an e99 f250 sd. Thanks
E99 F250 XLT SuperCab 4x4 3.73 gears, 213k and climbing, ZF6 trans w/ 1944-60K SB Clutch/Flywheel, 6637 filter, muffler/cat delete w/ 5 inch tip, PHP Hydra, 4 gauge pod(EGT, EOT, FUEL PSI, BOOST), 12000 lb Warn Winch, 07 headlights/grill, 6k HID kit, Bushwhacker pocket style fender flares, Pioneer 7" touchscreen, 2.5 inch leveling kit with 315/75/16 General AT2s on stock 16 bullets, HPX
Next up: Rebuild Kit and Billet Wheel, Fixing E-brake so I can park on hills!
Tow51Stang is offline
post #2 of 10 Old 03-29-2014, 11:26 AM
03ranger30's Avatar
EOT I am not sure of. EGT should be the back of the drivers side exhaust manifold, and fuel pressure should be at one the ports on the back of the fuel bowl. Since you have an e99 and don't have an AIH, you will have to drill and tap your intake spider after the intercooler, or you can tee it into the MAP sensor line.
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #3 of 10 Old 03-29-2014, 11:33 AM Thread Starter
Thanks now I just need 1 more!
post #4 of 10 Old 03-30-2014, 07:00 AM Thread Starter
Cant seem to find anywhere to put eot. Anyone??
post #5 of 10 Old 04-01-2014, 08:53 AM
is there even enough room to drill the hole for the egt probe?
Eta: Looked it up it appears you drill from under the truck?
2001 Power Stroker is offline
post #6 of 10 Old 04-01-2014, 02:05 PM
Googs's Avatar
If you look to the left of the oil filter you"ll find the spot, it's a 7/16'' socket you will need to remove the plug .The plug thread size is 1/8''NPT, hope this helps.
2003 F250 4X4 CC 7.3, 4R100HD
4' Turbo back exhaust, Banks Power Elbow, LPG (Gas over Diesel), DP Tuner F6, RR 6637 intake, RiffRaff Frx, Hpx, filter, Custom made transmission cooler with twin thermo fans, water to oil cooler, ScanGuage 2, Auto Meter, trans, EGT, Fuel pressure, Water to oil temp, Boost, Longrange fuel tank, 15000 Lbs winch, ARB winch bar, ARB lockers Fr & Rr, lightforce spot lights, HID's.
Googs is offline
post #7 of 10 Old 04-01-2014, 05:54 PM Thread Starter
Will oil come out of here when I pull the plug? I'm doing an oil change in a couple weeks so I can do it then if that's the case
post #8 of 10 Old 04-02-2014, 01:39 PM
Googs's Avatar
No you might just get a drip or two, just remember to use some thread or thread sealant on you sender.
Googs is offline
post #9 of 10 Old 04-03-2014, 07:21 AM
03ranger30's Avatar
There is barely enough room to drill, but it can be done.
Can't you get oil pressure readings from that plug as well? Or is that from someplace else?
Charlie
post #10 of 10 Old 04-03-2014, 12:44 PM
Googs's Avatar
Yeah, that's what I'm saying the plug on the filter housing is the best place to get your EOT .
Googs is offline
