DIY Brute 66? - Ford Powerstroke Diesel Forum
post #1 of 21 Old 03-28-2014, 04:50 PM Thread Starter
Joel's Avatar
Quoted: 10 Post(s)
DIY Brute 66?
Does anyone know if I can get a turbo intake housing that's ready to accept a 66mm billet wheel for the 38r?
Or is the stock shaft to small to use a bigger wheel?
I would think that the Van turbo's 1.15 exhaust housing would mate really well to this mod, if the pieces exist and are affordable.
Would this not be the same or very similar to a Brute 66?
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #2 of 21 Old 03-28-2014, 07:01 PM
03ranger30's Avatar
I am interested in this too. Would make a lot more sense to do this than spend $1300+ on a similar turbo.
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #3 of 21 Old 03-28-2014, 07:47 PM
They have a forum going right now and I just talked to the guy that does this kit. The thread is about doing it with e99 and obs trucks but he offers it for all of them.
Anyone interested in a DYI Billet 66mm OBS-E99 Kit - PowerStrokeArmy
E99 F250 XLT SuperCab 4x4 3.73 gears, 213k and climbing, ZF6 trans w/ 1944-60K SB Clutch/Flywheel, 6637 filter, muffler/cat delete w/ 5 inch tip, PHP Hydra, 4 gauge pod(EGT, EOT, FUEL PSI, BOOST), 12000 lb Warn Winch, 07 headlights/grill, 6k HID kit, Bushwhacker pocket style fender flares, Pioneer 7" touchscreen, 2.5 inch leveling kit with 315/75/16 General AT2s on stock 16 bullets, HPX
Next up: Rebuild Kit and Billet Wheel, Fixing E-brake so I can park on hills!
Tow51Stang is offline
post #4 of 21 Old 03-29-2014, 07:40 AM
blue99stroker's Avatar
Quoted: 258 Post(s)
that would be a cool setup. it would be similar to a brute66
i think most companies havent done this because they want to make more money off of you.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is online now
post #5 of 21 Old 03-30-2014, 03:56 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Barder that's doing that setup is an awesome company.
To make the van turbine housing work, do you not need a bigger turbine as well? I think there was just a thread on this
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #6 of 21 Old 03-30-2014, 07:47 AM Thread Starter
Joel's Avatar
Quoted: 10 Post(s)
I already have a van turbo in my truck.
I think I'll give Barder a call when I'm back in town.
$700 is more than I'm interested in spending right now, but I'll probably go that route when the time comes
Joel is offline
post #7 of 21 Old 03-30-2014, 08:58 AM
Quoted: 3 Post(s)
have you tried the ww2 in the stock housing with the van turbo?
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #8 of 21 Old 03-30-2014, 10:22 AM Thread Starter
Joel's Avatar
Quoted: 10 Post(s)
I have a billet wheel already, and it helped tremendously. But I'm willing to bet that with the 175/80 injectors I have, a 66mm wheel would be a big improvement.
Joel is offline
post #9 of 21 Old 03-30-2014, 01:04 PM
I just got a price from Barder.
Machining of the housings
Billet wheel
non-EBP pedestal
Van turbo adapter
seals/gaskets
$750
I might just try the WWII I have in the stock van compressor side.
Dan V is offline
post #10 of 21 Old 03-30-2014, 01:53 PM Thread Starter
Joel's Avatar
Quoted: 10 Post(s)
Billet wheel
non-EBP pedestal
Van turbo adapter
seals/gaskets
$750
I don't need the non-ebpv pedestal or the adapter.
If all I'm doing is a housing swap I don't see why I'd need the seals either.
All I need is the wheel, which we all know is $200 or so. So what will they charge just to machine the housing is the real question.
As long as a 38r wheel threads on to a stock shaft, we should be good to go
Joel is offline
