Factory boost numbers - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 23 Old 03-27-2014, 03:21 PM Thread Starter
Quoted: 3 Post(s)
Have a boost question, and for some reason, the site is not currently letting me search the forum for an answer. So if this is redundant, I apologize.
I have a 2002 ccsb, zf-6, 4x4, banks intake, mbrp 4"exhaust, factory injectors and turbo, canned ts-6, 235,000 miles. According to my torque app, I never produce over 14.9 psi boost, even WOT at the +100hp setting. I'm guessing that I either have a leak somewhere, or since this thing was bone stock when I bought it, there is an adjustment somewhere that I know nothing of, which will jump my numbers. Is the factory wastegate limited to 15 psi, and can I adjust it? I have seen other members with similar upgrades claim to get over 20 psi.
Any and all help is appreciated, but please understand that I cannot afford any more upgrades at this time and have to rely solely on tuning what I have at this point. I'm not upset with the performance I am getting, just want to peak what I have.
blkdrgn42 is offline
post #2 of 23 Old 03-27-2014, 03:43 PM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
My '02 made 22lbs Stock, 27lbs once chipped (80DD) and I have never touched the wastegate controls.
Somethings wrong...
NoRalPh is offline
post #3 of 23 Old 03-27-2014, 05:55 PM
PSD POWER007's Avatar
Quoted: 8 Post(s)
Send a message via AIM to PSD POWER007
Adjust the wastegate rod so that it takes about 25psi of regulated air to open it. My truck wouldn't make more than about 17psi until I adjusted mine. Check all of your intercooler boots to make sure they are tight. Especially the valley boots. Those get over looked.
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, DP-Tuner F6 Live tuned, 05 Harley's w/ HID conversion, Edge Insight CS, Dieselsite BRV & coolant filter, Factory 20" wheels, RiffRaff boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #4 of 23 Old 03-27-2014, 06:12 PM
belz's Avatar
Quoted: 70 Post(s)
Mine makes 28. Need to check if I have the wastegate connected or not.
belzfone
Belz
CPA Director
belz is offline
post #5 of 23 Old 03-27-2014, 06:53 PM
Joel's Avatar
Quoted: 10 Post(s)
Check for massive up-pipe leaks too.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #6 of 23 Old 03-28-2014, 03:48 AM
03ranger30's Avatar
I made around 17 stock, 22 in the 75 horse setting. About the same in every other tune as well. I think that's what the wastegate is set at, because if I unplug it, it will make over 25.
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #7 of 23 Old 03-28-2014, 07:58 AM
DIMBLEWAMBIE's Avatar
I can get up to 27-28lbs max, that's in 100+ DP tunes and wastegate unhooked. You've definitely got an issue somewhere, unless the torque app isn't that accurate? I've never used it, maybe someone who has can report what their readings are on it.
Justin DIMBLEWAMBIE Lamb
2002 F250 7.3l 4x4 CCLB
8in lift Deaver springs, Bilstein 5125s & 5160s
Toyo 37x13.50r17 MTs, Eagle Alloy 185s
F8 Destiny DP-Tuner & Dyno Proven
Banks Boost, EGT, Trans gauges
Banks straight pipe, K&N intake w/ 6637 filter
Banks EBPV-less elbow, Wastegate ON [OFF]
Foil delete mod, Zoodad mod
11" LED bar, 05-07 grill
DIMBLEWAMBIE is offline
post #8 of 23 Old 03-28-2014, 08:13 AM
RPM Tim's Avatar
You should not trust that reading>>>
Originally Posted by Peter@DP-Tuner View Post
Most tuners will manipulate what the PCM sees in order to get the fueling they are looking for. Hence the term "tuning". Your Torque app can only read what the PCM is seeing. It helps once you start running tunes, to find another source for reading boost besides the PCM.
2002
250 CCSB 4x4 7.3
stock~ diy B085011 / DEP 5" Turbo Back w/muffler / Phoenix chip
RPM Tim is offline
The Following User Says Thank You to RPM Tim For This Useful Post:
Redstroke188 (03-29-2014)
post #9 of 23 Old 03-28-2014, 09:27 AM
Joel's Avatar
Quoted: 10 Post(s)
Dude, your truck is freakin rad.
I really like how you kept the 7.3 bumper and lights too. Looks very classy
Joel is offline
post #10 of 23 Old 03-28-2014, 10:11 AM
RPM Tim's Avatar
DITO. I like the full chrome grill from 05-07, but definitely not a fan of a plastic bumper cover If I ever facelift mine it will have that look! Of course my truck is black with grey, but damn that blacked out w/ a chrome front is SEXY!
DIMBLEWAMBIE likes this.
2002
250 CCSB 4x4 7.3
RPM Tim is offline
