ts chip wont start - Ford Powerstroke Diesel Forum
post #1 of 14 Old 03-27-2014, 04:19 PM Thread Starter
ts chip wont start
Hey I got a ts chip for my truck and installed it two days ago. It worked great when I installed it with no issues. The truck sat yesterday being that I had the day off,and than thismorning it wouldnt start. I had no wait to start light which I had after installing the chip the other day. I disconnected the batteries and pulled the chip out and the trucl fired right up,So i disconnected the batteries again to plug the chip back in to assure it had a good connection. It still wouldnt start so I played with it a little more but still the same result so I just pulled the chip out. I emailed the company I bought it from thismorning but they havent gotten back to me yet so I figured maybe someone on here would know something about it I didnt. I read alot of people having starting problems due to not cleaning the connections good enough but I dont think thats my case because i had the chip working the other day. Thanks for any advice.
bluestar is offline
post #2 of 14 Old 03-27-2014, 04:28 PM
might have to clean a tiny bit more.
early 1999 F350 CC LB DRW Mark111 just bought/ php hydra, Tony's tunes, ISSPRO EV2
1996 F250 BTS Tymar, MBRP, Baby Swamps,Autometer
1996 F350 Mason dump plow truck
jasult is offline
post #3 of 14 Old 03-27-2014, 05:19 PM Thread Starter
It just doesnt make sence to me why it would work fine the first day and than stop, I figured if it wasnt getting a good enough connection it wouldnt work at all. But if it comes down to it guess ill have to thanks.
bluestar is offline
post #4 of 14 Old 03-27-2014, 05:21 PM
Ford7three's Avatar
Vibrations will cause weird things, like closing the door bumped it just right. But yes, it sounds just like a bad connection issue.
Ford7three is offline
post #5 of 14 Old 03-28-2014, 01:56 PM
DieselManor's Avatar
Clean it again. It may not make sense but that's the culprit. I had this problem too. Worked great for months, but when the temps dropped come winter, the truck wouldn't start. Take a razor and drag the edge over each connection on the computer. If you see any silicone come off then you didn't do a good enough job cleaning it.
David Murphy
DieselManor is offline
post #6 of 14 Old 03-28-2014, 07:29 PM Thread Starter
Alright I guess ill pull the computer and clean the connections more to see if it helps. Ive read of some people over cleaning the pins and it not working at all. Could this be done or is that just bs?
bluestar is offline
post #7 of 14 Old 03-28-2014, 07:59 PM
03ranger30's Avatar
Mine ran fine for about a month or so after installing the chip, and then out of nowhere it died and wouldn't start. Turned out I cleaned too much off the PCM and had to send it off to get re-tinned.
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #8 of 14 Old 03-29-2014, 02:41 PM Thread Starter
So that being the case how would I know weather I didnt clean enough or cleaned too much?
bluestar is offline
post #9 of 14 Old 03-29-2014, 03:09 PM
03ranger30's Avatar
If you cleaned it too much, there will be brass showing through the contacts. If you cleaned too little then there is probably still a little bit of silicon still on the contacts.
Sent from AutoGuide.com App
Charlie
post #10 of 14 Old 03-30-2014, 08:05 AM Thread Starter
I have a buddy that works on circuit boards at work and he told me that I want the brass to show because thats the conducting part is that not true in this case? Btw I cleaned it more and its working now.
bluestar is offline
