Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 11-17-2008, 11:27 AM
RRonning1984 RRonning1984 is online now
Heavy Equipment 911
10K vs 5.6K MOD
Well on a wild hair I took my 10K out and put a 5.6K in my truck. The diff was night and day. I didnt notice that big of a diff when I did the 10K but 5.6K is the way to go. My throttle is so snappy that its retarded and for the first time ever, my truck makes black smoke! Plus the kick in the pants from a dead stop is extreamly noticable.
I Highly recommend this mod to everyone.
Bonus, it didnt throw the low presure code on my truck!
As a warning, please make sure you have an EGT gauge if you are going to run anything lower then the 5.6K!
Old 11-17-2008, 11:53 AM
bigwhite7.3stroker bigwhite7.3stroker is offline
Florida Stroker
Awesome man thats good to know
Old 11-17-2008, 12:50 PM
szyd szyd is offline
I liked the 10k but took it out before i instaled the TW. And was told the chip will do what the 10k does and so far it has. Some run the 10k and chip. I never got a chance to try other versions
Old 11-17-2008, 05:55 PM
dubl_t dubl_t is offline
so you replaced the 10k resistor with a 5.6k resistor? I thought the 5.6k mod had to do with the IDM?
Old 11-19-2008, 04:43 PM
Heavy Equipment 911
No No, you just do it the same as the 10K and it makes a world of diff. Just make sure you wire it in to a switch cause the lope at idle can get annoing at long stop lights!
Old 11-19-2008, 05:03 PM
Jake Jake is offline
<-----GTP38R
I had a 4.somethin in mine, but the more aggressive i got with the resistor, the worse is shifted, it would shift real sloppy and slow, slipped alot.
Old 11-19-2008, 05:11 PM
Heavy Equipment 911
I like the 5.6 because the shift is firm but I cant have it on all the time or it will drive me nuts!
Old 11-19-2008, 08:20 PM
newlymowedlawns newlymowedlawns is offline
Newbie here what exactly is the 10k mod and the 5.6 k. Go ahead school me!
Old 11-20-2008, 10:20 AM
Heavy Equipment 911
Watch this vidio. It will walk you through the procees. Works on all 7.3L Powerstrokes. Resisters are 99 cents for 5 at any radio shack. Do the exact same thing with a 5.6K resister to do the 5.6K mod. Goodluck!
Diesel Movies - I install a 10k resistor in the ICP sensor of a 2001 F250 7.3L Powerstroke Diesel.
Old 11-20-2008, 10:50 AM
Stroker7.3 Stroker7.3 is offline
i pulled up next to a stroker with a 4k in it. I thought he had a cam in it before i asked him what it was. it sounded so cool and i want to try it but i have heard that it will break my edge juice????
