Help... Banks Ottomind? - Ford Powerstroke Diesel Forum
post #1 of 18 Old 10-29-2008, 04:33 PM Thread Starter
Mud-Nut's Avatar
Send a message via MSN to Mud-Nut
Hi there... As some of you know, I just bought a 2001 SD. The guy that owned the truck before me didn't seem to know much details about the truck. You guys already helped me figure out what kind of lift was installed on the truck. Now I need some more help....
I know for a fact that the truck has a Banks exhaust on it. But that's about all I know from my inspection.
But I found some sort of chip that was in the center console. It's a Banks OttoMind engine calibration module. Serial No. 011115, and on the back side of it, it says PowerPack 66504 PMT1.
It says on the front side, to only use with Banks system components.
My question is, what are all these components that I may have on my truck??? I know I have an exhaust on the truck, but I want to make sure I have everything else?
And I'd like to get a set of instructions for this chip... Could you get me a copy? I don't really know much about this???
Do you guys recommend I plug this thing in? Or just leave it out?
Let me know any information I could use... Thanks guys!!!!
2001 F250 (Extended Cab, Short Box)
7.3L,
, NV271, 5.5" Lift, 37" BFG Baja Military Tires, Recentered Powder Coated H1 Wheels, DIY Intake, 3.5" Exhaust, Autometer Gauges, '05 HD Headlights, and TW Tuned!
1979 F150 (Regular Cab, Short Box)
460 BBF w/ Nitrous, C6, NP203, 14B FF Locked, HP D60 w/ Spun Inner C's, 5.13 Gears, 39.5" Boggers, Built Bumpers, Warn M12000, Built Front Radius Arms, Built Rear Shackle Flip (in progress), and much more...
Mud-Nut is offline
post #2 of 18 Old 10-29-2008, 04:44 PM
CSIPSD's Avatar
Get a pic of under the hood, specificly the exhaust side of the turbo and the wastegate rod.
Does it have gauges?
There are no directions for the chip, its a single pos chip, I would bet a 60hp program.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 18 Old 10-29-2008, 04:44 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Its mild power increase chip from Banks. Made for towing. IIRC its 40 to 60 hp increase. The PMT 1 code on it tells me it should be the one for your truck
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #4 of 18 Old 10-29-2008, 05:09 PM
durawut's Avatar
YEAH plug it in!! my old 7.3 had the banks ottomind chip and i put a tunner on top of it, worked well. The dude before you probly had the bighoss bundle installed check for bighoss waist gate on the turbo and maybe an optional larger inter-cooler to make sure. then if u look underneath somewhere buy the tranny he may have had a banks trans command installed also. if not these will all work well together! one more thing the chip is mapped around ur cpu so it will not be compatible with other strokers! hope this shed a lil light on the situation.
p.s. I had a ton more mods on my 2000 7.3 so if u want some ideas or have any questions you know where to find me
durawut is offline
post #5 of 18 Old 10-29-2008, 09:21 PM Thread Starter
Mud-Nut's Avatar
Alright.... I'll take pics tomorrow.
It doesn't have gauges.... I want to get a set of gauges though.
To be completely honest with you, I don't even know where the chip plugs in?
Good to know it's suppose to be for my truck.... But I'm wondering why it was in the center console, and not plugged in? Hmmmmm....
Cool... I'll check the intercooler and tranny, see what's there. I plan on doing some major modding with this truck, but not for another year or so. I have other projects and school to worry about right now. I'm just trying to learn as much as I can right now, and try to figure out what was done to my truck already.
Thanks for the replies guys!
7.3L,
Mud-Nut is offline
post #6 of 18 Old 10-30-2008, 04:50 PM Thread Starter
Mud-Nut's Avatar
I emailed Banks about this matter.... Here's what they told me:
"The Ottomind chip you have is for a Banks PowerPack system. This is a 100 hp system. The PowerPack consists of The Monster Exhaust, Banks Turbo housing, Big Head wastegate actuator, intercooler and Ottomind chip."
Now....... I'd like some help making sure I have all these parts on my truck. I know for a fact that I have the exhaust.
As for the intercooler... Where can I look for a Banks stamp or something? I looked at the intercooler, and I can only really see a tiny bit of it on each side. So I'm having a hard time figuring out if it's the stock intercooler, or a Banks one.
And I'm not too sure exactly what the turbo housing is??? And I'm not sure what the stock wastegate and "Big Head" wastegate look like. Can you guys help me from these pics?!
Thanks guys!!!!
7.3L,
Mud-Nut is offline
post #7 of 18 Old 10-30-2008, 07:21 PM
Cj Ford's Avatar
turbo and waste gate look stock to me ..downpipe has a bung welded in for a pyrometer but you should install yours in the drivers side manifold... you need to know how hot the exhaust goin into the turbo is.. not so much as the temp of it coming out of the turbo
1999 F250 XLT 2WD 7.3, 6 spd, South Bend Con OFE, Detroit Truetrac, Tony Wildman tunes, Autometer Boost&Pyro, AFE Stage II, 4" MBRP Exhaust, 2" Daystars, 17x9 DC1 wheels wrapped in 33x12.50 MTZ's
Chris
Cj Ford is offline
post #8 of 18 Old 10-30-2008, 07:57 PM
Dirty, looks dirty
2000 F-350
7.3L 6spd 71xxx miles
Zero Mods
3/01/2008 - 3/25/08
Zoodad and Foil Delete 3/26/08
DIY Intake 6/25/08
4" TB exhaust 7/01/08
TW 6pos chip 7/27/08
HP oil crossover 7/27/08
'05-'07 Front end conversion 1/8/10
UnlimitedLove is offline
post #9 of 18 Old 10-31-2008, 01:44 AM
molokai's Avatar
Trash the banks a get a DP or TW they are both custom burn chips only for your truck.
molokai is offline
post #10 of 18 Old 11-01-2008, 04:26 AM Thread Starter
Mud-Nut's Avatar
Hmmm... Alright. That would explain why the chip was in the console. Prolly makes the truck running worse than stock without all those parts.
I'm pretty sure the intercooler is stock as well. I couldn't see any Banks stamps anywhere on it.
And yeah.... I plan to eventually run a DP chip, along with other stuff. I was just curious as to what was already installed on my truck.
7.3L,
Mud-Nut is offline
