Uncork to Tow? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 16 Old 02-12-2014, 04:51 PM Thread Starter
SmittyMT's Avatar
Uncork to Tow?
Hey Fellas, newbie to the forum. Picked up a 2000, 350, 6-speed stick, CCLB, 196k, 6637 mod, stancor, leveled, 305/70/16 toyoMTs, stock exhaust. No gauges yet. 3.73. Previous owner hauled log furniture on a goose neck.
My point of this is I just purchased a 26ft toyhauler 6,700lbs empty. I pulled it from Pueblo, CO to Fort Collins, CO. It pulled great through 3rd, then it was gutless through 4th and 5th gears. I could barely make it to 55mph on straight aways and touched 60s going downhill.
Had a lumen cause issues when I first got the truck and my specialist check my injector and compression of one cylinder. Compression was 380 on a cold day (20 F) at about 5k elevation. He only checked the one cylinder.
Will a tuner really uncork my truck, or am I in need of more mods to open her up...I was disappointed to say the least, when I was nearly floored and barely touching 55 on I-25.
I'm from Montana and heading back in March w/the trailer. Just want to figure out what to do before I trek across Wyoming pulling my toys.
Thanks in advance for the help!
SmittyMT is offline
post #2 of 16 Old 02-12-2014, 04:55 PM
Quoted: 2 Post(s)
Please post pics of truck with those tires
SmittyMT likes this.
2000 f-250 superduty
leveled on 375/65/16 MTZ's 16x12 Classic 3,"X" code front leafs, afe stage 2 intake, 175/80 p.i.s injectors, 38R turbo, Adrenaline hpop,ITP return fuel sys with reg,
4" from turbo back, lentech built trans, 12 billet converter, DP tuner!!!
krs1r/t is offline
post #3 of 16 Old 02-12-2014, 04:57 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Sounds like you have other issues... likely some major boost leaking or up pipe leak.
You should be able to pull a 6700lb trailer and not have any issue.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
The Following User Says Thank You to schlutzer For This Useful Post:
SmittyMT (02-12-2014)
post #4 of 16 Old 02-12-2014, 04:58 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
tuner helps, but excessive egts from just a tuner will damage your engine.
a free flowing intake and exhaust is a must.
egt gauge at least and boost if you want, boost gauge can help with troubleshooting boost leaks.
a billet hweel will fix turbo surge and lower egts/ produce more boost/power.
a good 6 pos chip from php, gearhead, no limit, or tony wlildman will be your best bet for tuning.
edge, superchips, bullydog, banks etc are garbage compared to the names listed above.
and ya you have issues if you cant get ot 55 mpg haha
check for blow by by flipping oil filler cap upside down and if it vibrates off your fine if it blows off you have issues.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is online now
The Following User Says Thank You to blue99stroker For This Useful Post:
post #5 of 16 Old 02-12-2014, 05:07 PM
Quoted: 27 Post(s)
What kinda tunes you running!?!?! j/k lol. But to the op yea you got some other problems if your having trouble with that.
strokin-7.3 is offline
post #6 of 16 Old 02-12-2014, 05:58 PM
FWIW I have pulled at 8-10k trailer up into Colorado from Texas for years with -0- issues. Truck has been totally stock. The only place it had a hard time was up Raton pass, then it would only do like 45mph. Other than that it would go as fast as you wanted.
2002 F-250 199K crew cab 2x2, auto, PHP Hydra, Isspro, and intake.
cpa7man is offline
post #7 of 16 Old 02-12-2014, 06:33 PM
Jerrybizzle's Avatar
Quoted: 21 Post(s)
Mine had issues with my 6500-7000 pound camper up the large mountain passes around here when stock, would drop to second at 45 mph and 3100 rpm. After chip it holds 3rd at 65 pretty easily up the same pass now. Stock it would still get up to speed and hold od on the flats.
2012 f250CCLB, 35x12.5/17 Kanati mud hogs on race line assault wheels, 2 inch lift
Mini maxx
Jerrybizzle is offline
The Following User Says Thank You to Jerrybizzle For This Useful Post:
post #8 of 16 Old 02-12-2014, 06:42 PM
I had a 2001 f350 with a 6 speed, and I found that towing my 4500# travel trailer without a tuner, it was gutless. Couldn't really hold it in 5th gear going up hills. I added a superchips tuner, and it really helped. I would just leave it in light tow mode, and I could easily go up hills in 5th after that. Even starting out helped too. Before, I would need to start in low on slight inclines, then with the tuner, I could start out in 1st with no problems.
My truck had 4inch exhaust from the turbo.
I live in Alberta, Canada. Foothills of the Rocky Mountains so I am familiar with towing on hills and through the mountains! Lol
fordfan76 is offline
The Following User Says Thank You to fordfan76 For This Useful Post:
post #9 of 16 Old 02-12-2014, 09:36 PM Thread Starter
SmittyMT's Avatar
Thanks for the input guys. I'm busier than a cat tryin to bury a turd on a marble floor. I'll drop it by my specialist tomorrow, run some of the ideas by him that you fellas gave me and see what he can figure out.
Thanks a ton for the input. I've read through the tuner forums and will definitely be picking one up soon. I also uploaded a couple pics for show and tell.
I'll update the thread when I hear back.
BTW this forum kicks ***.
2000 F350 CCLB 6 speed sticky, 6637, stancor, leveled, 305/70/16 ToyoMTs, more to come
SmittyMT is offline
post #10 of 16 Old 02-12-2014, 09:41 PM
Irishpilot's Avatar
Let us know what you find out. Your truck should do better than that, even at 5,000' elevation
2000 Crew Cab F250 4x4:
Performance: Bone Stock
Mods: Indash Kenwood DVD/Nav, 08+ power/lighted/heat tow mirrors
Irishpilot is offline
