Normal fuel pressure range? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 02-12-2014, 03:37 PM Thread Starter
Quoted: 2 Post(s)
Since I finally got my Glowshift fuel pressure working ... What is a good base fuel pressure on these 7.3s?
My gauge is showing 69.
winona78 is offline
post #2 of 14 Old 02-12-2014, 03:40 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 331 Post(s)
You're actually a bit high it should be around 60 tops. But i don't think it will hurt anything. By the way did you use the upper plug or the lower one? The lower is after filter pressure.
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #3 of 14 Old 02-12-2014, 03:48 PM Thread Starter
Quoted: 2 Post(s)
I used the lower one. Will that cause the higher range?
winona78 is offline
post #4 of 14 Old 02-12-2014, 05:04 PM
LoxDiesel's Avatar
Quoted: 331 Post(s)
Someone could have modified the spring. Regulator is on the top RH side of the fuel bowl. It has 2 torx head screws holding it on. But if you're going to tear into it I highly recommend resealing the whole housing. Dieselorings.com sells a kit for pretty cheap. 20$ or so. Idk if someone else will chime in but i've heard glowshifts FP sender is inaccurate. Again i wouldn't worry about it. Its not off the charts too high.
@loxdce
post #5 of 14 Old 02-12-2014, 06:52 PM
CSIPSD's Avatar
No... He is not.
He is spot on where it should be.
Normal pressure is between 65-72psi. Anything above 60psi is fine.
60psi tops... Where to people come up with this?
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
The Following User Says Thank You to CSIPSD For This Useful Post:
winona78 (02-13-2014)
post #6 of 14 Old 02-12-2014, 07:05 PM
03ranger30's Avatar
Where should you take the pressure from? The upper or lower plug?
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #7 of 14 Old 02-12-2014, 09:04 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
I used the upper plug, drivers side of the bowl
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #8 of 14 Old 02-13-2014, 07:49 AM Thread Starter
Quoted: 2 Post(s)
Thank you guys for the help. This forum is so awesome!
@03ranger... the glowshift adapter I bought showed to use the lower plug.
winona78 is offline
post #9 of 14 Old 02-13-2014, 07:52 AM
PSD POWER007's Avatar
Quoted: 8 Post(s)
Send a message via AIM to PSD POWER007
I would prefer post filter pressure readings, so I'd use the lower port.
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, DP-Tuner F6 Live tuned, 05 Harley's w/ HID conversion, Edge Insight CS, Dieselsite BRV & coolant filter, Factory 20" wheels, RiffRaff boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #10 of 14 Old 02-13-2014, 08:20 AM
CSIPSD's Avatar
It really doesnt matter that much, upper or lower... Just having a baseline is the most important thing.
Joe
CSIPSD is offline
