Glowshift Fuel Pressure gauge issue - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-11-2014, 07:40 PM Thread Starter
Quoted: 2 Post(s)
Hopefully someone will have an idea of what is going on. I have the 3 pillar gauges from ISSPRO (pyro, trans temp, boost)that came with the truck, but wanted to get a fuel pressure gauge. I went with glowshift one. Well, I installed it... and it doesn't do anything. Not even light up.
Here are the instructions...
http://www.glowshift.com/instruction...sure-Gauge.pdf
The yellow is running to a 12v source that my ISSPRO uses and is based the ignition. Red is right to positive battery. Orange is not used as I always drive with my headlights on. Green goes right to the sensor. Then the two grounds I ran under the dash in the fuse area where everything else is grounded. As far as I can tell, I have it wired properly. Obviously the gauge says something different.
Any ideas at all? For some reason my Pyrometer stopped working too... Think that is connected to the fuel pressure gauge or do you think I just disconnected it on accident? Thanks!
***I did contact Glowshift already tonight too, but want to get some feedback from you guys****
winona78 is offline
post #2 of 2 Old 02-12-2014, 02:36 PM Thread Starter
Quoted: 2 Post(s)
Figured out the problem. The wire I thought I was connecting to a ignition switch 12v was actually not. Got a fuse tap and it works now.
winona78 is offline
