New TS chip and now injector knock! - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-08-2014, 08:32 AM Thread Starter
Strokeittothemax's Avatar
Just got a ts chip installed and the truck gets a injector knock sometimes and will smooth out! Does it off and on with the power levels! So I just need injectors soon since it has 145,000 miles or a fuel problem you think? Also can u just let it knock til one starts missing then if I'm just going to need new injectors soon? Appreciate any input! Thanks!
~Ryan~
Present: 2002 F350 XLT CCLB Dually 7.3L, TS-6pos, 4" Exhaust
2013 Ford Focus ST Black
Past: 2012 CCSB 3500 Cummins (Dads now)
2007 Crew Cab Short Box F250 Lariat 6.0L
2004 CCSB LB7 Duramax EFI Live
Strokeittothemax is offline
post #2 of 10 Old 02-08-2014, 09:01 AM
Quoted: 788 Post(s)
Probably due to tuning on the chip. Timing advanced too far??
Corey@CNCFAB is offline
post #3 of 10 Old 02-09-2014, 11:14 AM Thread Starter
It seemed to go away some now so not sure! It is a TS canned tunes from them I believe so could it have timing issues even if there the canned tunes?
~Ryan~
post #4 of 10 Old 02-09-2014, 11:26 AM
Have you checked the base fuel pressure at wot? If it starves for fuel pressure it will make a knocking sound
Power-Struck dot com
POWER-STRUCK is offline
post #5 of 10 Old 02-09-2014, 06:41 PM
blue99stroker's Avatar
Quoted: 261 Post(s)
i agree. a fpr rebuild with a billet regulator may be in your future.
my fpr was worn out pretty bad when i replaced it, 220k miles on it so ya...
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is online now
post #6 of 10 Old 02-09-2014, 06:54 PM
Rodslinger's B1TCH
does it knock on all power settings? does it do it on stock too? i know my engine was really noisy on the 100hp ts setting. it was ok on the 75 hp setting
steve604 is offline
post #7 of 10 Old 02-10-2014, 06:47 AM Thread Starter
Did it on stock after for a little bit then quit. blue99stroker, how much did that cost you?
~Ryan~
post #8 of 10 Old 02-10-2014, 11:25 AM
Quoted: 261 Post(s)
FPR rebuild kit is 60 bucks. the brass poppet valve and orings get worn out.
a billet fpr housing with 3 stiffer fuel pressure springs is 42 bucks from dieselorings.
post #9 of 10 Old 02-10-2014, 11:28 AM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
it prolly has an issue it's just that the new chip is showing more because it's pushing the outer limits of it...could be tunes, could be the pcm learning procces after the new chip
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #10 of 10 Old 02-10-2014, 04:10 PM
Rodslinger's B1TCH
i'm going to go with pre-existing condition that the chip is helping you identify.
like blue99stroker says, you probably need to fix the fpr
steve604 is offline
