2000 7.3 best tuner? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 42 Old 02-06-2014, 05:27 PM Thread Starter
Hi I just bought a sclb 2000 f350 with 115k. Im wondering whats the best tuner for the 7.3s I was going to buy a 6.0 so I knew what I wanted but then this deal came up. It has an edge insight in it I believe at the moment 3 settings tow race and extreme. But I feel like theres betters out there with more power. Alot of people have been trying to talk me into the TS 6pos tuner. But I figured id ask and see what you guys use and like thanks!
s10pete is offline
post #2 of 42 Old 02-06-2014, 05:59 PM
wick07's Avatar
There is a million post on this it you had searched first but since u didn't. The ts is a good option because many company's can burn custom tunes to them. The hydra is another good one. Edge, superchips are all generic and don't do much for supporting mods. I assume your truck is stock. The 7.3l is a slow *** ***** I love mine but you need to do a few more mods to wake her up
2000 F-250 Superduty, 4" magna flow, K&n intake system with AFe big boost filter, 6" skyjacker lift w/ 37" toyos, riffraff over boost fooler, riffraff intercooler boots, riffraff fuel cross over & oil cross over, warn hubs, gauges, chip, new engine
wick07 is offline
post #3 of 42 Old 02-07-2014, 02:41 PM Thread Starter
Thanks I looked just didnt see much for what I was looking for for an answer and it has a 4 inch straight pipe intake bigger turbo and tranny rebuild with a hd torque coverter its pretty fast for a 7.3 I thought cause I know they are normally nutless. But I was also wondering could I stack the edge tuner with the TS ?
s10pete is offline
post #4 of 42 Old 02-08-2014, 11:24 AM
blue99stroker's Avatar
Quoted: 258 Post(s)
cant stack chips on 7.3's
a ts chip with custom tunes is better than edge.
blue99stroker is offline
post #5 of 42 Old 02-08-2014, 11:40 AM
Rodslinger's B1TCH
my vote for THE BEST TUNER is going to be the PHP hydra along with boost, pyro and trans temp gauges installed
PHP phoenix chip would be my next best recomendation
the TS is ok for the price but after having one myself i would spend the $50 extra on a PHP phoenix. the TS will burn up the pistons over time if you're going to use the power.
i have an old edge evolution that is retired to the glove box for code reader duties only until i get an auto enginuity set up.
Chatham036 likes this.
steve604 is offline
post #6 of 42 Old 02-09-2014, 09:55 AM
Joe0816's Avatar
I have never heard of ts burning up pistons. On my last truck I had a ts 6 position chip and everyone I know with 7.3s have ts 6 position chips. Definatly go either php or ts. Next question if you go ts is who will you have custom tune it. I did have a problem with my ts, though. I called ts and I sent it to them on a Monday, they got it, and sent me a brand new chip, which I received it on Friday and installed. The problem is that it was jumping in between tunes, say I was in high idle (OBS didn't have High idle factory) it would jump out then go back in making it sound like someone was slightly revving it.
2001 F250 ECLB 7.3 PSD 219,000 miles
S&B Intake
Flo-Pro 5" SS Exhaust
ISSPRO EV2 Boost, Pyro, Trans
David Lott Tunes
Riffraff HPx, FRx & AIH Delete
Resse Gooseneck Hitch
Non-EBPV Turbo
Joe0816 is offline
post #7 of 42 Old 02-09-2014, 03:23 PM
Rodslinger's B1TCH
the TS causes much higher EGT than PHP tunes. I can easily get above 1200 in the 75 hp setting. with PHP's 80hp setting I can't get above 1200 and there is much more power there.
EGT's burn up pistons. It happens to many people. after having both tunes i would never go back to TS tunes.
steve604 is offline
post #8 of 42 Old 02-09-2014, 03:37 PM
Joe0816's Avatar
Are you saying theoretically or you have actually seen burnt up pistons from a ts? Has anyone else had both ts and php and agree with steve? Now you have me interested and questioning my choice of ts. Are all of the tunes the same from php whether on the chip like yours, the hydra, or the phoenix? Not very familiar with PHP.
S&B Intake
David Lott Tunes
Non-EBPV Turbo
Joe0816 is offline
post #9 of 42 Old 02-09-2014, 03:59 PM
Rodslinger's B1TCH
i have not seen or heard of burnt pistons necessarily due to TS programming per say, just due to high EGT's. I know that with the TS i can easily get into the danager zones and could easily hold my EGT's at 13-1400 for an extended period of time while towing through mountain passes (see Highway through hell on discovery). i had to switch it to stock in the summer while towing a trailer.
PHP tunes with more power run 400+ degrees cooler with no smoke.
i miss the smoke though...
steve604 is offline
post #10 of 42 Old 02-09-2014, 04:07 PM
Raul@Stealth Automotive's Avatar
Tony Wildman Performance Chips gets my vote
Raul@Stealth Automotive is offline
