fianally h2e vs phatshaft turbo - Ford Powerstroke Diesel Forum
post #1 of 25 Old 02-05-2014, 06:58 PM Thread Starter
need in put.very upset.i finally upgraded to a h2e from a phatshaft turbo. lots of head ache installing it after all not a drop in turbo.it was a used kit that i bought had to make my own down pipe.modify a new hypermax boost tube.but got it all together.thought it would be a big diffence but not!went for road test ran good no waste gate so full boost all the time.but spool upwas the same if not slower ,egts the same i thought it would be lower with i thought a bigger turbo.still lots of smoke at low rpms as well on upper rpms.even on the 80 econo tune.just dont under stand.everything i read on here h2e is the ticket with what i have.the same egt at the end of a 1/4 mile run.even is the same with water/meth is 1589 ext temp before turbo wtf!!!! need some input.want bigger sticks but need help
2000 f250 crew cab 4x4 ,forged rods ,dp f5 modified stock 60 tow 80 econo 120 race 120 race with water methanol ,4" turbo back exhaust,jobe air intake,boost fooler,snow performance stage 3,all gauges,shift kit and triple disk billet converter,big oil,stage 2 single shots100% nozzles,h2e turbo , arp head studs,comp 910 springs ,diesel innovations regulated return ,air dog 150 with 1/2"pick up
irocz28 is offline
post #2 of 25 Old 02-05-2014, 07:01 PM
schlutzer's Avatar
Quoted: 18 Post(s)
okay.... uh what are you asking?
None of that makes any sense to me and I tried reading it twice.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 25 Old 02-05-2014, 07:06 PM Thread Starter
i had a phat shaft turbo spent big money to upgrade and not seat of the pants diffence what's the deal that is all i'am wondering.not an ace at typing.thanks
just need help on why gets are the same and no performance diff.
irocz28 is offline
post #4 of 25 Old 02-05-2014, 07:16 PM
PSD POWER007's Avatar
Quoted: 8 Post(s)
Send a message via AIM to PSD POWER007
LOL...that made my head hurt...
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, DP-Tuner F6 Live tuned, 05 Harley's w/ HID conversion, Edge Insight CS, Dieselsite BRV & coolant filter, Factory 20" wheels, RiffRaff boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #5 of 25 Old 02-05-2014, 07:20 PM
schlutzer's Avatar
Quoted: 18 Post(s)
"phatshaft turbo" doesn't tell us anything. I've never heard of that turbo, what are the specs?
post #6 of 25 Old 02-05-2014, 07:28 PM Thread Starter
you havent heard of it?phatshaft, ball busterbig bad wolf? itflows the same if not more than a gt38r. but is not a ball turbo.
irocz28 is offline
post #7 of 25 Old 02-05-2014, 07:38 PM
schlutzer's Avatar
Quoted: 18 Post(s)
That is not a common turbo so no, me and most other probably haven't heard of it.
Only info I can find is that Is a ball bearing turbo, comparable to the 38r
Look good luck, your posts are way too hard to read for me to try and help.
post #8 of 25 Old 02-05-2014, 08:21 PM
I would like to know more on this also, getting to put an h2e in my truck
Sent from AutoGuide.com App
treemover is offline
post #9 of 25 Old 02-05-2014, 08:28 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
csipsd is running an h2e with bigger injectors than you and doesnt have issues with egts like you do. something is wrong.
different tuning could be in your future as well
and they make a billet wheel option for the h2e, which would help egts, spool etc.
blue99stroker is offline
post #10 of 25 Old 02-05-2014, 08:34 PM
schlutzer's Avatar
Quoted: 18 Post(s)
See and I thought he was saying he went from the h2e to this other one
