dp f5 chip questions - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-04-2014, 10:51 PM
stormtroopered7.3
Guest
Posts: n/a
Quoted: Post(s)
Ok so just got my truck and the only mods done are a 7 inch stack and an aftermarket remote start. I was looking into chips and tuners and im leaning toward the dp f-5 chip because I have seen alot of good reviews. Im sort of new to the diesel world so I was just wondering if i should do any other mods before I get the chip. I figure I would get better results from the chip if I upgrade the intake and the injectors but I dont have that kind of money right now so will I still get good results with everything else being stock or will I just be wasting my time? Also wondering if I will run into mechanical issues later on from running the chip on a stock truck?
post #2 of 4 Old 02-05-2014, 07:19 AM
SeeYa's Avatar
You will want to do gauges to monitor EGT's. On a truck that is this old you will want to check the truck out prior to doing anything to it. Anything mechanically wrong will just be emphasized.
Custom Tuning-Computer Chips
Flash Programmers-Aftermarket parts
Ford Power Stroke Engine and Transmission Tuning Specialist since 2004.
828-221-0076
SeeYa is offline
post #3 of 4 Old 02-05-2014, 04:39 PM
Joel's Avatar
Quoted: 10 Post(s)
I think it's worth it to go with the F6 so that you can easily have updated or additional tunes emailed to you.
Gauges are considered a must, but even more so if you can't afford intake and exhaust yet. The restrictions there will almost for sure result in high EGT's
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #4 of 4 Old 02-07-2014, 10:53 AM
CSIPSD's Avatar
Check out the Hydra chip...
Power Hungry Performance Hydra Chip
Better chip, better tuning and cheaper... Not to mention anyone can send you tunes for a Hydra...
Do the math, to order a DP chip and "load it" your over $700+... You get the same thing with the Hydra for $375... and its better tuning, better options and you can run anyones tunes...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
