Twin fuel pump kit - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-03-2014, 03:41 PM Thread Starter
Twin fuel pump kit
Somewhere a while back i thought i saw a bracket and harness set up for running twin fuel pumps on a 7.3 250. I cant seem to find it again. I checked several of the usual aftermarket sites. Is anyone familiar with this set up and where i may find the parts?
Gas Trader is offline
post #2 of 8 Old 02-03-2014, 06:49 PM
Joel's Avatar
Quoted: 10 Post(s)
I've never seen a kit, but it's a pretty simple DIY project if you decide to do it yourself.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 8 Old 02-04-2014, 08:09 AM
Checkout Dynoproven on Facebook. They posted a picture of one today that they are going to sell.
Paul
01 F350 CC 4 x 4 LWB, not running yet.
SOLD...03 f250 CC 4x4
PHP Hydra, AIS w/fender sleeve, Magna Flow 4" Dual Exh, Warn Premium Hubs, Skyjacker Leveling Kit, CTS Insight for monitoring, Ranch Hand GG, Riff Raff boots, Riff Raff IAH Delete, Riff Raff HPX, Riff Raff FRX, Foil Delete, CCV Mod
trlrdrinla is offline
post #4 of 8 Old 02-05-2014, 06:07 AM
Here's how to make the bracket and install the pump
Welcome to guzzle's Helper/Lift pump Web Page
I would use another stock pump, not the 6-8 psi pump he uses.
2002 F-250, 289,000 miles, 89,000 on WVO; Greasecar conversion, 20 plate heat exchanger, AIH delete-water injection in its place, DIY fuel bowl delete, 6637 air filter w/cover, Straight Piped, GPR LED mod, CAT ELC, 203* thermostat, Bosch aux coolant pump, ext coolant filter, fumoto oil drain valve, Aeroforce Interceptor scan gauge, ISSPro trans temp, boost, EGT, elec fuel pressure gauges, Cyberdyne coolant, veg oil, ambient air temp gauges, 80W low beams/100W high beams. No grease problems.
kirkh is offline
post #5 of 8 Old 12-29-2015, 03:22 PM
BigT2000's Avatar
Quoted: 10 Post(s)
Garage
what would be the purpose of duel pumps ?
BigT2000 is offline
post #6 of 8 Old 12-29-2015, 03:28 PM
Hate stupid people
CloverLeafFarm's Avatar
Quoted: 144 Post(s)
Just another fueling route to go with.
More of a backup option if 1 goes bad.
But not necessary as they rarely goes out.
My single competition fuel pump kit from irate diesel is still rolling around with over 100 k miles on it
Illiana Strokers DICtator
EFI Live tuned 6.7
CloverLeafFarm is offline
post #7 of 8 Old 12-29-2015, 04:36 PM
Quoted: 28 Post(s)
As cloverleaf said its a good way to have a backup.
But different form what he did by going with the upgraded single pump to fuel bigger injectors you can do the same with dual stock pumps.
Fairly cheap to build a DIY kit. Most people already have 1 pump. The stock pump is fairly cheap from RiffRaff. If one goes out its cheap to replace.
Easier to build a DIY now because some of the places that sell kits will sell specific parts like a harness if you call and talk to them.
2000 F-250 XCLB 4x4 6 Speed, PIS 175/80's, ARP's, 910's, Irate Fuel, 6637, GTP38R, 4" turbo back, Hydra PHP tuned, International Up-pipes, ISSPRO Boost, EGT, HPOP and Fuel Pressure gauges. SB Clutch. MB Diesel HPOP stage 2.
CarportMechanic is offline
post #8 of 8 Old 12-30-2015, 02:18 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Okay that guzzles link and running dual factory setups is completely different.
Personally, what was done with the two pumps in series I think is a waste, the benefits would be extremely marginal, if any. On a stock truck, the stock pump will easily keep you above 60PSI.
Running dual OEM pumps in parallel will allow you to cheaply support even as big as a 300/200 injector, providing you can make the kit yourself, if you're buying one and you actually need increased fuel available, its hard to beat the single pumps buy Aeromotive and Fuel lab.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
