Seafoam in a 7.3 - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-03-2014, 02:13 PM Thread Starter
Joe0816's Avatar
Seafoam in a 7.3
Before I jump and start doing things, is it okay to put seafoam in a vacuum line? I want to throw a can in vacuum and a can of trans tune in transmission. Thanks!
2001 F250 ECLB 7.3 PSD 219,000 miles
S&B Intake
Flo-Pro 5" SS Exhaust
ISSPRO EV2 Boost, Pyro, Trans
David Lott Tunes
Riffraff HPx, FRx & AIH Delete
Resse Gooseneck Hitch
Non-EBPV Turbo
Joe0816 is offline
post #2 of 11 Old 02-03-2014, 04:26 PM
Vannnce's Avatar
Quoted: 13 Post(s)
Ive never had of putting it in a vacuum line on a diesel... but ive hadgood luck with it in tank with my 7.3
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #3 of 11 Old 02-03-2014, 05:18 PM
Quoted: 14 Post(s)
Why would you put it in the vac system? The vac system isn't connected to the engine in any meaningful way that needs "flushing".
ttyR2 is offline
post #4 of 11 Old 02-03-2014, 06:24 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Yeah theres no vacuum line to put it in.
And I've read its a big no-no to put it in our oil.
My fuel system definitely likes it though
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #5 of 11 Old 02-03-2014, 08:09 PM Thread Starter
Joe0816's Avatar
Yeah I just popped my hood and realized that, I guess I have been spending too much time with my ranger lately haha. I did splash a little in the fuel bowl, though.
S&B Intake
David Lott Tunes
Non-EBPV Turbo
Joe0816 is offline
post #6 of 11 Old 02-03-2014, 08:29 PM
Rodslinger's B1TCH
i read that a lot of guys drain the fuel bowl and fill with seafoam and then put the rest in the tank. the truck ran scary smooth and quiet for a while after i did this.
steve604 is offline
post #7 of 11 Old 02-04-2014, 06:48 PM Thread Starter
Joe0816's Avatar
Yeah I heard transmission fluid will also smooth out the idle, a quart in a tank.
S&B Intake
David Lott Tunes
Non-EBPV Turbo
Joe0816 is offline
post #8 of 11 Old 02-16-2014, 05:00 PM
That's what I do
Sent from AutoGuide.com App
Travis T
1999.2"5 F350 4X4 CC 7.3 LWB SuperLift, AIS, Gooseneck, Zoodad, South Texas Outfitters Bumpers, Autoenginuity Ford 4R100HD
2002 F250 2X4 CC SWB (Wife's) Stock except for AIS filter and Gooseneck
cadd is offline
post #9 of 11 Old 02-16-2014, 05:29 PM
ars5147's Avatar
Quoted: 127 Post(s)
Food for Thought
The stuff is about 20% Isopropyl Alcohol. I know there are other additives but the alcohol is what cleans everything. Not a problem in a gasser but we need fuel (and it's additives) to lube the injectors.
Most likely the short time of running it (if you fill your bowl), it probably won't hurt anything though.
Just posting this for some food for thought.
Here's the MSDS: http://seafoamsales.com/wp-content/u...seafoam_EN.pdf
2008 F250 CCSB 6.4
1997 F350 CCLB 7.3
2011 F150 SVT Raptor
ars5147 is offline
post #10 of 11 Old 02-16-2014, 06:38 PM
Rodslinger's B1TCH
I'm thinking that the fuel side of the heui injector isn't all that fragile. The oil side of it is the part where the problems happen.
A common rail injector is a different story.
steve604 is offline
Tags
diesel , seafoam , trans , tune , vacuum
