No more Raped Ape?
Ok got the truck back Mods are in my sig. Forged 2000 motor replaced my 02 PMR with the vent ports on each side of the block. however my truck no longer runs like a raped ape. on my 80 tune i can barely make 25lbs of boost and it is not making the power. my 120 tune feels the exact same thing little more smoke. my modified stock program feels Stock. before it felt grunty like my 80econo tune before the turbo and injectors.
Any suggestions? |
Could be a fuel system problem.
check the fuel system thinking it might be some Algea growing didnt see anysigns on the filter. driving it around today it seemed to open up more I took a small bottle of Power Service during fill up today gonna run a bottle thru then go back to 2 stroke oil.
Alright driving it around a bit it seems to be comming back to normal slowly. other then filling up and the fuel gauge not reading full i noticed its not picking up its shifts i think the tranny might be slipping. I can feel it want to shift then BLAM its shifts.
So i put the truck into my tow program and it accually seemed to run better with more reponse. im gonna have my buddy at work ride with me he is more knowledgeable about trannies then i. |
Maybe need to reburn ur chip to support your new mods?
the chip was already burned for the injectors and turbo and valve body. the PMR's couldnt handle it so a new Donor engine with Forged rods took its place. all the electronics from the 2002 motor are on the 2000 motor now. another update the Fuel Milage seems to be great. filled up last night, needle didnt move off of F until 126 miles when i finally got home the needle had just slipped under the "F" at about 152 miles If i remember correct.
I would say air in the system not worked out yet... how many miles on the donor motor?
110k miles on it.
i think he means how many miles have you put on it since the swap. but i could have misunderstood
Yes, how many miles on the swap... Might take as much as 100 miles to clean it out.
