Need Advice on SCT Tuner SF3 - Ford Powerstroke Diesel Forum
Old 10-17-2008, 05:42 PM
I got an SCT SF3 tuner from a friend. I already have intake, and straight exhaust. Has anyone heard anything good or bad about these. I tow 10,000 LBS. And set it to tow mode, but there's no info on HP of Torque ratings. I see a huge difference but I also want to be reliable. Here's a link to the tuner SCT Automotive Performance Products
Old 10-17-2008, 05:59 PM
they are the best tuners for the 6.0 .......if you dont have head studs you'll be ok as long as you dont go ripping around all the time ......get yourself some guages so you can monitor your egt's and you should be ok .....alot of people get custom tunes for them witch makes a big diffrence ......but im sure alot of other people will chime in too .....so good luck and have fun
Old 10-17-2008, 06:05 PM
yeah def the best tuner out there for the 6.0 and def get gauges (boost, egt, tranny if you want) you will be fine towing in the tow tune also.
Old 10-17-2008, 06:06 PM
Send a message via AIM to troid123
gauges for sure...I would not run any tuner without at least having gauges, especially if you are towing with it.
Old 10-17-2008, 06:20 PM
another thing, if you call Innovative diesel, get the street/tow tune, you can tow 10K with 400HP.....not a bad deal, there man.
Old 10-18-2008, 04:52 AM
I actually have the 7.3 How are they on those engines??
Old 10-18-2008, 05:14 AM
Almostdunfukinwidit
I ran one on my old 7.3 with innovatives tuning. Loved it
Old 10-18-2008, 07:08 AM
Cynic
Why not just put Tony Wildman tunes on that SCT and call it a day?
Old 10-18-2008, 12:54 PM
Almostdunfukinwidit
Dirk unless something has changed that i do not know about Tony is not writing SCT files. Jody does though
Old 10-18-2008, 12:58 PM
innovative has pretty good tunes for the 7.3L....
but...
with the 7.3L you have the option of going with a on the fly switchable chip.... with that SCT youll have to do the whole loading and unloading process....
up to you
but not matter what you need gauges...
-Raul
