oil pressure gauge - Ford Powerstroke Diesel Forum
Old 10-15-2008, 12:21 PM
Send a message via AIM to hartman99
oil pressure gauge
Just got an oil pressure gauge not to long ago and was wondering where is the best/easyiest place to hook it up? It looks like the sending unit screws in some where then theres a wire comin off it.... i just dont kniow where it screws into
early 99 f350ccsb
Old 10-16-2008, 02:44 PM
The Screwy HEUI
What brand & what model do you have?
Old 10-18-2008, 06:41 AM
I think many do it back on the rear of the motor somewhere, to see the actual pressure at the main bearing? There is a 1/8" NPT plug back there?
Otherwise you can do it on the HPOP reservoir, but in some peoples opinion that is not the most accurate place. (Mine too from what I have read on the forums)
Old 10-21-2008, 06:52 PM
ok ... there auto meter c2 gauges
Old 10-21-2008, 08:46 PM
I just did mine today, there is a 1/8th inch NPT port with a male square head plug in it on the drivers side of the block, just in front of the bell housing. There is also 2 more plugs in the same general area with female square head plugs - don't use these, 1 is coolant, the other is a metric thread.
Old 10-23-2008, 01:15 PM
alright thanks alot man!
