Question - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-27-2014, 12:53 PM Thread Starter
shortrac's Avatar
Question
Would a power inverter off the battery's of a truck run the block heater if u put a Timer on it set at 1 hour before u left work to warm the block. Is it a dumb idea when u have to park ur truck n a lot n leave it for 10 hours a day when it can't b plugged n when it 10 outside?
startin over with a stock 2000 f250 crew cab 4x4 shortbox lariat w/288k miles
shortrac is offline
post #2 of 2 Old 01-27-2014, 01:01 PM
Macon's Avatar
To limit the chance of killing your battery, I would suggest doing what you said, but with a spare battery in the bed. Trickle charge that battery when you're home for the night.
Or, get a battery select switch mounted in the cab and disconnect whichever battery you have the inverter connected to.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
