largest split shot injectors? - Ford Powerstroke Diesel Forum
Old 10-13-2008, 11:00 PM
What is the largest split shot type injector upgrade? I don't want single shots as they make the engine rattle sound louder..more then my likings. Even with good tuning they are not as quiet. Im looking for the biggest upgrade while maintaining the splitshot. Thanks
Old 10-13-2008, 11:02 PM
You can go as big as you want, but you better have dual high pressure oil pumps to supply them... Whos truck have you heard with single shot injectors? I dont think they are any louder other then at idle?
Old 10-13-2008, 11:13 PM
just some on youtube in the past. do you have videos of single shot injectors? I hate the rattly sound of the obs 7.3's that didnt have split shots
Old 10-13-2008, 11:17 PM
I tell you what I will do... I should be home tomarrow night or latest wednesday. When I get home I will take a video of my truck and my wifes excursion and you can see if you can tell...
Other then knowing mine has single shot, I doubt you will be able to tell.
Old 10-14-2008, 07:09 AM
Sounds like a deal to me! Thanks!
Old 10-14-2008, 07:17 AM
Cynic
Single shots are quite a bit louder. I was noticing that a weekend or to ago. I was comparing my hybrids vs. BI's.
Old 10-14-2008, 07:24 AM
You can get B-codes in a split shot, they are definitley going to need alot of oil though.
Old 10-14-2008, 09:25 AM
another thing to think about is that it isn't fair to compare an OBS to a Superduty as far as interior noise. The OBS basically only had a heat sheild on the engine side of the firewall. The Superduty has close to the same heat sheild, plus a 1" foam pad and a thick hard place cover on the interior of the cab.
I seriously doubt the interior noise of a superduty will change a whole lot from splits to singles... but I agree, the exterior noise will change a lot.
Old 10-14-2008, 09:33 AM
Cynic
Mine did. Quite a bit.
Old 10-14-2008, 09:38 AM
Mine changed alittle bit, alittle rougher at idle, but nothing really noticable at speed, expect when you WOT I could hear my exhuast change pitch from before single shots
