I need some turbo advice - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-25-2014, 08:50 PM Thread Starter
82 wild bill's Avatar
I pulled my turbo off to change my up pipes when I noticed my ebpv was leaking and when I went to remove my waste gate line the nipple broke off the waste gate PA salt = rust it's a never ending battle. I was wondering if I should do an ebpv delete since I guess all they do is leak??? I was looking at a 1.00 ar turbine housing that is non waste gated about the same price as a good wastegate, I was going to put in a ww2 also, is this a good way to go??? Or is a good waste gate better??? My truck is primarily a daily driver but I do tow heavy on the weekends around 20,000lbs I could use all the help I can get with egt . Stock injectors I was also using my ebpv to warm up my truck and as an exhaust brake is this a bad idea???
82 wild bill is offline
post #2 of 3 Old 01-25-2014, 09:00 PM Thread Starter
It is an 01 6 speed with tony wild man tunes stock injectors 4 inch down pipe wicked wheel CCV mod and custom cold air intake based off the afe stage 2
post #3 of 3 Old 01-26-2014, 05:40 AM Thread Starter
I am thinking about going with the non waste gated 1.0 A/R exhaust housing $180, billet compressor wheel $200,and the high flow outlet $115 with the non ebpv pedestal blank $110. I think this would make a good turbo setup for $500 plus eliminate my oil leak for another $110. Does anybody have any options on this setup or have one like it???
Tags
turbine housing , wastegate , wicked wheel , ww2
