Used chip? - Ford Powerstroke Diesel Forum
Old 10-11-2008, 03:46 AM
Used chip?
I'm thinking about buying a used TW chip. He said the chip is for a TDE1 PCM, so I need to find out what I have - where the hell do I look, and do you guys recomend a used chip, or should I just hold out & get a new one?
Old 10-11-2008, 03:50 AM
Pcm code is on the PCM you need to remove it to see it. And if youre code is different TW can burn to youre code I believe $150.00
Old 10-11-2008, 05:12 AM
Feedback Score: 3 reviews
Your truck is alot newer, your prolly have a vdh4 pcm code. Chip will need to be reburned for your truck.
Old 10-11-2008, 06:53 AM
Powerstroke Junkie
The man himself has spoken!!!
And you don't need to remove the PCM, you can use a mirror on a stick and a flashlight on the engine side and you can read the code, but it can be a pain, but it can be done as I have done it several times.
NCH
