Garret 38R - Ford Powerstroke Diesel Forum
post #1 of 10 Old 01-22-2014, 05:48 PM Thread Starter
ja_cain's Avatar
Garret 38R
I am looking for someone in the Richmond, VA area that is running a 38R with preferably some 160/stock or 160/30 nozzles. I am interested in eventually running a setup like this but would like to experience it first hand (especially the turbo). I want to make sure that I can live with the sound of a 38R. I am seriously considering this or a Brute 66 but am intrigued with the quick spool characteristics of the 38R versus the stock or Brute 66 turbo. I have a straight drive and feel that it will be more enjoyable to drive with a quick spooling turbo. If there is any one out there that is near me I would love check out your ride.
JC
2002 F-350 SCLB PSD 4X4 6 Speed
ja_cain is offline
post #2 of 10 Old 01-22-2014, 08:37 PM
Joel's Avatar
Quoted: 10 Post(s)
Good luck.
Here's a bump for you
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 10 Old 01-23-2014, 06:20 AM
PSD POWER007's Avatar
Quoted: 8 Post(s)
Send a message via AIM to PSD POWER007
Not anywhere near your area, but I have a 38r with the WW2 and running 175/80's from PIS. The turbo doesn't sound much different than a stocker with the original WW or WW2. Just a slight whistle. It spools instantly and pulls all the way through the power band that I use. Even on stock injectors, this is the turbo the truck should've came with. I have NO regrets!!
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, DP-Tuner F6 Live tuned, 05 Harley's w/ HID conversion, Edge Insight CS, Dieselsite BRV & coolant filter, Factory 20" wheels, RiffRaff boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #4 of 10 Old 01-23-2014, 04:37 PM Thread Starter
ja_cain's Avatar
Thanks for the bump Joel.
ja_cain is offline
post #5 of 10 Old 01-23-2014, 05:51 PM Thread Starter
ja_cain's Avatar
Can't see your sig from phone, do you have pmr's with that setup? I am seriously considering getting the 170/80 from PIS, and then having someone detune them until I can pick up a forged rod motor. I'm not really looking for more than 400 hp at the wheels. The most important thing is quick spool up especially with a stick. I rarely run the truck over 2100 rpms unless I am towing something. Just wish I could find someone in my area that had a setup close to what I am looking at. Thanks again for the info.
ja_cain is offline
post #6 of 10 Old 01-23-2014, 06:34 PM
Exactly right on that part....noise on the other hand is a good bit louder than my stocker with a WW2...not that it's a bad thing cause I like the 38R sound myself.
2003 F250 7.3, PHP Phoenix, 4"exaust, Banks Big Head, WW2, Tymar, 4" lift with 35's
Montgomery P-Stroke is offline
post #7 of 10 Old 01-23-2014, 06:37 PM
Quoted: 8 Post(s)
Yes, I have a PMR motor. 400-425 hp was my end goal. My truck is a daily driver that I tow with regularly. So reliability is key. I feel totally safe with my set up.
The Following User Says Thank You to PSD POWER007 For This Useful Post:
ja_cain (01-23-2014)
post #8 of 10 Old 01-23-2014, 06:40 PM
Quoted: 8 Post(s)
I don't notice much difference in sound between the stock turbo with a WW2 and the 38r with WW2. A very slight more whistle on the 38r, but not much. I do have an AIS though.
post #9 of 10 Old 01-23-2014, 07:11 PM Thread Starter
ja_cain's Avatar
Thanks guys. My plan is to run an ais. I have a feeling this attenuates the sound of the 38r significantly vs the ever popular tymar intake that a lot of people run. I think that I am definitely set on getting the 38r with the WW based on my driving habits and what kind of power band I am looking for. Just need to decide on which injectors to go with (160/30 vs 175/80).
ja_cain is offline
post #10 of 10 Old 01-23-2014, 08:00 PM
You got me thinking and I did forget one fact on the sound. My brother is the one with the 38R (but exactly the same truck as mine..identical besides the front seat..same color..same year...close on build date). The previous owner did a foil delete on the ic pipes so that may make it louder than it should be. Both of us are running the Tymar style intake. My WW2 doesn't make hardly any more noise than stock until it's above 2k rpm. My brother's 38R makes noise as soon as you touch the go pedal but the extra power down low is well worth the noise if your pulling in stop and go traffic with stock sticks.
