walbro pump,sump and prepump filter - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-21-2014, 10:06 PM Thread Starter
Feedback Score: -1 reviews
I have the driven diesel prepump filter setup. its a water/air separation,harpoon mod. im currently running a walbro pump. Id like to set up a sump,running it to the filter system then the pump.
would this work? is there any issues that would pop up using this method?
2000 7.3 ccsb BTS 4r100,frx,coolant filter,custom intake,mbrp turbo back,Php FU,walbro 392,hi flow outlet,turbo master
Pro comp 6.5,bilstein 5160 front/rear,pro comp ladder bars,moto metals/37" hankooks.
n54power is offline
post #2 of 5 Old 01-22-2014, 06:59 AM
CSIPSD's Avatar
Why do you want to run a sump?
Beyond that... I would keep a spare fuel pump on hand running that Walbro. Went thru 6 of them before I went back to a Bosch pump.
Before you talk a hole saw to the bottom of your tank... Wait a little longer.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 5 Old 01-22-2014, 08:27 AM Thread Starter
guess I'm lucky. Same walbro for 70k. Now it will die since I bragged. I've got a fuel lab from a Subaru build thst make take its place.same model strictly/xdp ext sells
The reason for the sump is that last little bit of fuel and maybe the diesel thieves will cut the line instead of a hole in my tank. I'm on my thrice
n54power is offline
post #4 of 5 Old 01-22-2014, 09:43 AM
CSIPSD's Avatar
Holy hell! There cutting your tank? Wow!
Joe
CSIPSD is offline
post #5 of 5 Old 01-22-2014, 11:58 AM Thread Starter
Yah. I put a locking cap,cut line. Made a better skid and they drummer
n54power is offline
