Fuel Systems...Shed some light on me - Ford Powerstroke Diesel Forum
post #1 of 16 Old 10-08-2008, 05:29 PM Thread Starter
blowinsmoke7.3's Avatar
What are they? lol i know nothing about them, tryin to gain a little knowledge on them...FASS and systems of that nature and also on the regulated return
Thanks guys
blowinsmoke7.3 is offline
post #2 of 16 Old 10-09-2008, 12:23 PM
tubular031's Avatar
ITP 7.3L "Standard" Regulated Return Kit
http://www.dieselsite.com/index.asp?...ROD&ProdID=466
the regulated return will not really add power. Its a supporting mod. It also keeps fuel flowing through the heads, so the rails stay full and air has an excape path. the stock fuel system puts fuel into the fuel rails and the only way for the fuel to get out is through the injectors. I plan on the itp bowl delete kit some day.
Just a basic 01 F350 CCLB SRW -Good from a far but far from good
tubular031 is offline
post #3 of 16 Old 10-09-2008, 04:15 PM
Powerstroke Junkie
NCHornet's Avatar
Tubular explained the return, and there is also a cross over line, cheaper than a reg return, and will will connect both heads so #8 isn't the dead head injector.
The other fuel systems are used to eliminate the stock fuel filter and pump. This is usually done for modified trucks running bigger injectors, turbo etc.. all of these require more fuel than the stock system can provide. There is a very definite line you come to when modifying a 7.3, look at my sig. becuz I am on that line and can't afford to cross it!! The next step is the big one, bigger injectors, this means more oil Pressure so Big Oilcomes next ( not will all injectors, but with the big boys) this also meansmore fuel, so FASS or other fuel system, more fulemeans more air, so larger turbo, parts alone = $8K-$10K, as I said my truck has all the power for this poorman!! I'll leave the big HP numbers to the young kids without a wife and kids!!! lol!!
NCH
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #4 of 16 Old 10-10-2008, 01:11 PM
layson's Avatar
Quoted: 79 Post(s)
One thing about the Fass system is you don't have to have a regulator for your regulated return... the fass system has it already in it...
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #5 of 16 Old 10-10-2008, 03:09 PM
Strictly Diesel's Avatar
Watch that though, the FASS has been shipping with a regulator that will only do pressures in the low 50s from what customers are reporting.
Also, to clarify what NCHornet said...not all fuel systems eliminate the factory filter bowl or factory pump. My standard regulated return is used all the time, keeps the factory filter bowl and keeps the factory pump and does a great job on trucks that are even "near stock". You don't have to have big power to benefit from fuel system upgrades.
Dennis Schroeder - Co-Owner of Strictly Diesel
Race Truck :: 6050# / 11.31 @ 120mph / Best 60' of 1.56 ... with "Built" Race Engine (Fuel Only!)
Strictly Diesel is offline
post #6 of 16 Old 10-10-2008, 03:24 PM
PSDfan99's Avatar
Dennis, what are the determining factors when a customer either orders the fuel bowl delete kit RR or the standard RR kit? I'm going to be ordering one of the 2 from you some time shortly and don't really know which one I "should" get. I always thought the delete kit was mainly meant for dual HPOP trucks? Any benefit to the delete kit on a truck running a single HPOP?
Early 99 F-350
4" lift on 33's
Tymar Intake, Isspro Gauges, Modded IDM, HPX, Boost Fooler, 4" Exhaust
-BTS Tranny
-76mm Sledgehammer
-Swamps Tuning
-230cc Casserly Hybrids
-T.E. Modded 17* HPOP
-ARP's, Chromoly's, 910's
-ITP RR
-Jake
PSDfan99 is offline
post #7 of 16 Old 10-11-2008, 09:27 AM
Considering that Dockboy had enough fuel for an 11 second pass in a full size 4x4 while still running the filter bowl and my older 1/4" fuel lines (lines are now 3/8"), I can't tell you that it's a particular power level.
The answer is really..."personal preference". I tell a LOT of people to keep the filter bowl. Deleting it cleans up the valley, makes work on the HPOP easier and looks nicer...but you have to replace that filter with something else in the 2 micron range that is POST PUMP. In your case, staying with a single pump, I'd probably suggest keeping the bowl and using the "standard" kit.
Just so it's clear, the bowl delete wasn't developed to be a kit I expected everyone to use. It's been way more popular than I ever expected. That's great for sales, but I never expected to spend so much time helping people decide which way to go. It was designed for those doing "big oil", compound turbos, etc...those needing more space in the valley to work. Development of it was pushed by a few of my big HP customers. For the most part I figure that if you don't already know why you'd want/need it...you probably don't need it.
I hope that answers your questions and maybe clarifies things for others too.
post #8 of 16 Old 10-11-2008, 09:48 AM
PSDfan99's Avatar
Well that answered all my questions, thanks very much!
Early 99 F-350
4" lift on 33's
-BTS Tranny
-76mm Sledgehammer
-Swamps Tuning
-ITP RR
-Jake
PSDfan99 is offline
post #9 of 16 Old 10-11-2008, 12:28 PM
CUMMINS_KILLA99's Avatar
NCH
this maybe a dumb question but what is this cross over line you speak of your not talkin about the hpx crossover are you
99.5 F-250 4X4 LARIAT
35IN. BFG KM2s
2.5 IN. LEVELING KIT
AEM AIR INTAKE
TS CHIP (TUNED BY MATT @ GEARHEAD)
GARRETT 38R TURBO
6.0 INTERCOOLER
4IN. TURBO BACK EXHAUST
CSE FAB SINGLE BLACK 8IN. SLASH CUT STACK
CCV MOD
CSE PRE PUMP KIT
TRANNY COOLER WITH FAN
CSE FAB PORTED EXHAUST FLANGE
TIM MOYE TRANSMISSION
CUMMINS_KILLA99 is offline
post #10 of 16 Old 10-11-2008, 03:07 PM
No, it's a fuel crossover line that connects the fuel channels at the back of the heads. It's supposed to help with fuel pressure to both fuel channels, especially the injector #8 which gets starved under WOT conditions. It's a "poor mans" RR system, although it doesn't really regulate anything.
'06 F-350 SRW 6.0 PSD
Albin is offline
