Wicked wheel - Ford Powerstroke Diesel Forum
post #1 of 13 Old 10-08-2008, 09:52 AM Thread Starter
CYates73's Avatar
Wicked wheel
I am interested in getting a wicked wheel and I was wondering how hard it is to install... I have heard that you can install it while the turbo is still on... is that true? also what does it do for HP, anything? and does the wicked wheel make the turbo sound any different then when having the stock wheel installed? Any other opinions feel free to drop some
2002 7.3L
4 door 4x4
AFE stage 2 extreme
zoodad mod
4" magnaflow from turbo back
4-6" tip
TSD 6 position chip
stock, high idle, economy (80), tow (80), hot 1 (120), hot 2 (140)
10.5" BDS lift
40/17R16.5 ground hawgs
16.5" x 14" weld racing rims
autometer c2 gauges, trans temp, pyro, boost
6.0 trans cooler conversion
CYates73 is offline
post #2 of 13 Old 10-08-2008, 09:58 AM
layson's Avatar
Quoted: 82 Post(s)
HP nothing...
Yes you can install it with the turbo still in the truck... but it is fairly easy to just pull the turbo. Otherwise you will have to stuff a screwdriver into the exhaust wheel...
It will make more whistle then the stock wheel.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #3 of 13 Old 10-08-2008, 10:02 AM
RadarRider's Avatar
Originally Posted by layson View Post
HP nothing...
Just to add to this: pulling the turbo will also reveal if you have any issues with your uppipes. When I pulled my turbo, I found I needed to have new uppipes fabricated. I also had to replace the clamps on the flange @ the collector(left side had actually fallen out!). Like layson said, you won't increase HP, but you'll be spooling a lot earlier than with the stock wheel!
"HEAVY" 2001 F-250 XLT 4x4 EC SB:
TW 6pos chip, S&B CAI, Monster 4" exhaust w/ Power Elbow, Big Head WGA, Technicooler, ITP boost fooler, Gen 1 Wicked Wheel, Six-Gun Tuner, Optima Yellow Tops, AutoMeter(Boost, Trans, EGT), CCV mod, MTS TC, MTS valve body, Trans Tech performance rebuild kit, TransGo shift kit, Hornblasters 242 Shocker Train Horns.
RadarRider is offline
post #4 of 13 Old 10-08-2008, 10:04 AM
layson's Avatar
Quoted: 82 Post(s)
http://www.blackclouddiesel.com/Tech...on%20Guide.pdf
without removing the turbo...
Quote of the Day:
layson is offline
post #5 of 13 Old 10-08-2008, 10:31 AM
Cory S's Avatar
is it the same on an obs???
Vegistrokin
2000 XC 4x4
-CORY
Orlando, FL
Cory S is offline
post #6 of 13 Old 10-08-2008, 10:33 AM
RadarRider's Avatar
Minus the intercooler pipes...yep.
post #7 of 13 Old 10-08-2008, 01:06 PM
payne5757's Avatar
HP nothing...
Exactly! I left mine on since I didnt wanna mess with the oil o-rings and it took me less than 3 hrs. Sounds great.
2000 Ford F250 Super Duty Powerstroke ( 7,460lbs 5in rough country lift, 18in XD Revolvers, 35in Dura Grapplers, bilsteins all around, 4in.MBRPstraight pipe,WW,TS 6 pos chip,TS Monitor w/HUD,Tymar,map fooler,foil delete, zoodad, Kenwood stereo, pioneer 6x8s, JL 500V1 amp, and one JL12w7)
payne5757 is offline
post #8 of 13 Old 10-08-2008, 01:18 PM
drstephennix's Avatar
Quoted: 2 Post(s)
Send a message via Yahoo to drstephennix
You dont need a wicked whell on an OBS....it already has one from the factory
2011 F-350 CCSB KR 4x4
35" Hancook AT's
AFE CAI
6.7 Scorpion
197k miles
Back in the diesel game!
In the words of David Crockett, "You may all go to hell. I will go to Texas!" spoken in the halls of congress; circa 1830's
drstephennix is offline
post #9 of 13 Old 10-08-2008, 01:55 PM Thread Starter
CYates73's Avatar
After adding the wicked wheel it will increase the sound of the turbo? would it be easier to leave the turbo on the truck or to take it out? So will I feel a difference in the truck when I have the WW installed?
2002 7.3L
4 door 4x4
AFE stage 2 extreme
zoodad mod
4-6" tip
TSD 6 position chip
10.5" BDS lift
CYates73 is offline
post #10 of 13 Old 10-08-2008, 01:56 PM
Quoted: 2 Post(s)
You wont feel a difference, just hear it. and I did mine with the turbo on
35" Hancook AT's
AFE CAI
6.7 Scorpion
197k miles
