Need Injectors Which Ones tho? - Ford Powerstroke Diesel Forum
post #1 of 19 Old 01-18-2014, 08:54 AM Thread Starter
I have been looking at PIS,full force,swamps and unlimited diesel injectors but I don't no which ones r the best or if they r all bout the same. I am looking for a little more power like stage 1. My truck is a 2000 f250 with 236000 miles on it and it will not start at all if it gets like 35 and below and it sits over night u better have it plugged in. It has new gp and gpr and new icp sensor. Any Suggestions wat else it could be or wat for injectors to go with. Thanks
00ryanstroker is offline
post #2 of 19 Old 01-18-2014, 09:05 AM
nine6stroker's Avatar
Quoted: 35 Post(s)
You can't really go wrong with any of the good names. I bought my injectors through Beans Diesel Performance, who I was told gets theirs from Full Force. I have about 40k on them and have not had a single issue!
1996 F250 7.3 PSD 4x4 - "Dally"
281k miles
BDP stage 1's, T500 HPOP, TS6 chip, KC38r turbo, stock trans and fuel
Sitting on 2006 F-350 axles and suspension
nine6stroker is offline
post #3 of 19 Old 01-18-2014, 09:12 AM
Thuglike's Avatar
All the big names are good as mentioned...I believe P.I.S. and Rosewood are having sales right now. I would look at them first.
Plus very few guys are better to deal with than Tim and Jm.
Thuglike is offline
post #4 of 19 Old 01-20-2014, 09:13 AM
CSIPSD's Avatar
My vote goes to Tim at Performance Injection Systems...
www.performanceinjectionsystems.com
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #5 of 19 Old 01-20-2014, 12:13 PM
New or remans?
Dan V is offline
post #6 of 19 Old 01-20-2014, 12:24 PM
Quoted: 2 Post(s)
I got pis remans, love them
2000 f-250 superduty
leveled on 375/65/16 MTZ's 16x12 Classic 3,"X" code front leafs, afe stage 2 intake, 175/80 p.i.s injectors, 38R turbo, Adrenaline hpop,ITP return fuel sys with reg,
4" from turbo back, lentech built trans, 12 billet converter, DP tuner!!!
krs1r/t is offline
post #7 of 19 Old 01-20-2014, 12:28 PM
CSIPSD's Avatar
Reman's or new, they all go thru the same process, and are all ballanced.
Mine are my own wore out injectors, completely gone thru with all parts replaced. Best injectors I have ever run!
Joe
CSIPSD is offline
post #8 of 19 Old 01-20-2014, 12:38 PM
Any benefit from sending your own injectors in and having those reman'd...or just send'em in as cores?
Dan V is offline
post #9 of 19 Old 01-20-2014, 12:42 PM
CSIPSD's Avatar
My motor was blown at the time... I sent in the injectors out of my donor motor at the same time...
Advantage? No core charge...
Other then that, none.
Joe
CSIPSD is offline
post #10 of 19 Old 01-20-2014, 12:55 PM
Quoted: 904 Post(s)
Feedback Score: 3 reviews
You can't go wrong with any of them but if your really on a budget, Rosewood would be my choice in your shoes.
Have you ever had feelings for a nun??? "Nacho Libre"
Corey@CNCFAB is online now
