Fuel pickup foot necessary? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-17-2014, 05:24 PM Thread Starter
WVRidgeRunner's Avatar
I'm planning on doing the hutch/harpoon mods (Using Strictly Diesel's kit) in the morning and have no idea what shape my fuel pickup foot is in. Pulling the bed for some other maintenance so it'll be easy to get to. I called a couple ford dealers around here to see if they had one just in case but nobody can get one til wednesday. If my foot is broken, do I even need it? The kit I'm using has a prepump filter. I could see needing something on the end of the line to block big pieces but I'm thinking I could run to NAPA and get a universal sock to put on it if necessary. Just trying to cover my bases ahead of time, always like to have a plan. I searched but couldn't find where anyone said "run it barefoot with no pickup foot and no worries" or "no matter what you do don't start it without the foot on it!" Thanks for the suggestions
1999.5 707 Conversions Super Duty 7.3 Crew Cab LB Dually 4x4 Edge Evolution, Oil HPx, Fuel FRx, tons of filters, hutched n harpooned, B&W turnover ball and 5th wheel, lotsa goodies.
WVRidgeRunner is offline
post #2 of 9 Old 01-17-2014, 06:15 PM
Joel's Avatar
Quoted: 10 Post(s)
I don't think you NEED it, but there is the chance that something close to 3/8 in diameter could get lodged in there down the road and then you would be in trouble.
It's probably un likely though.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 9 Old 01-17-2014, 07:39 PM
machinestheman's Avatar
I'm crossing the same bridge aswell putting my rr kit and I'm ripping the filters and mixer out but I don't think I will sleep better at night knowing theirs less chance of a clog
01 f 450 6sp 4WD
DIY intake with prefilter, CCV mod, IAH delete, Granatelli big G monitor with electronic fuel pressure sender, sinister diesel coolant filter, muffler delete and hollow cat, IH bellowed up pipes, polished intake spyder, 203 thermostat, billet fpr housing, hpx hard line.
machinestheman is offline
post #4 of 9 Old 01-18-2014, 04:58 PM Thread Starter
Foot turned out to be fine.
Got the hutch and harpoon done, it's an hour job once the bed is off.
Also pulled the bed, removed the front bed floor crossmember and fabricated a new one, beat/ground/chiseled all the rust off the frame and crossmembers from the cab back to bare metal, and got a coat of rust converter on all of it.
Tomorrow is fab the other bed floor crossmembers and paint the frame.
Had a little trouble with the strictly diesel kit, 2 of the hose clamps stripped and one of the studs on the bracket broke loose so I couldn't tighten it. No big deal I had hose clamps and just welded the stud back. All in all, the install was simple. Getting that fuel tank plastic ring back on was the worst part of the whole mess, would've been much easier with a second pair of hands I took a lot of pics just haven't uploaded them yet. Once it's all done I'll get pics up. Really happy with all of it so far.
post #5 of 9 Old 01-21-2014, 05:32 AM
Ace7.3's Avatar
Did it quiet the motor down much? I've been debating on doing this but not feeling like dropping the tank or lifting the bed.
2012 3/4 Lariat 4WD leveled and 35's
Sold: 2002 3/4 Lariat,DIY,Zoodad,boost fooler,CCV,HPX,EBPV,Wicked wheel,Auto Meter gauges,Edge Evo II 100 horse,MBRP 4",203*
Ace7.3 is offline
post #6 of 9 Old 01-21-2014, 11:04 AM
PSD POWER007's Avatar
Quoted: 8 Post(s)
Send a message via AIM to PSD POWER007
Having to drop the tank is what's kept me from doing this.
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, DP-Tuner F6 Live tuned, 05 Harley's w/ HID conversion, Edge Insight CS, Dieselsite BRV & coolant filter, Factory 20" wheels, RiffRaff boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #7 of 9 Old 01-21-2014, 11:52 AM
Quoted: 172 Post(s)
Feedback Score: 3 reviews
It's really not that bad a job.....
What I did was, drove around until the "Low Fuel" light came on and then parked it. I then connected a hose to the drain tube (from the Filter Housing's yellow lever, on the rt side, next to the exhaust manifold). Then I took my starter pak and powered the fuel pump.
This emptied the tank (left only about a Qt of fuel) AND gave me a good indication of how much fuel I had left when the light came on (@5gal.). With the tank empty, dropping it was an, easy, "1-man job".
Go spray some PB Blaster on those long threads that hold the tank strap now
NoRalPh is offline
post #8 of 9 Old 01-21-2014, 12:31 PM
CSIPSD's Avatar
You dont need the pickup foot. I dont have one, of course I am running a 5/8" pickup... but none the less just cut your in tank kit to where its 1/2" off the bottom of the tank.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #9 of 9 Old 01-21-2014, 04:43 PM Thread Starter
Pulling the bed wasn't that big of a deal but I did it at work with a crane. Other than having a couple minor issues with the kit I bought from strictly diesel, I highly recommend the hutch mod. In conjunction with Riff Raff's fuel rail crossover, truck is MUCH quiter than before. I'm figuring out photobucket so I can post the pics and I'll put a thread up in the 7.3 general forum
