Head stud install - Ford Powerstroke Diesel Forum
post #1 of 49 Old 10-05-2008, 08:38 AM Thread Starter
cchase's Avatar
Head stud install
Hey,
How hard is to install headstuds?
And the big question is do I have to take out the motor? If I dont I would think about putting it in the shop and doing it myself, but if I got to pull the motor, id just spend the 500 and have them put in. Also, do the injectors need to come out?
Thanks
Chris
On vacation from a truck for a year or...
Looking at 6.4s Moving in a few months then hopefully buying my dream truck!!!
Driving an Audi till then...
but at work I drive
16 E-450s 7.3 powerstroke Ambulances
7 Duramaxes
1 GMC Kodiak Ambulance
NO CUMMINS.....
cchase is offline
post #2 of 49 Old 10-05-2008, 09:13 AM
farmboypowerstroke's Avatar
you do not have to pull the motor
farmboypowerstroke is offline
post #3 of 49 Old 10-05-2008, 09:21 AM
siloped's Avatar
it looks like it would be awfully hard to put the cylinder head back on afterwards. Or trying to slide the studs in the bolt hole on the rear of the motor
99 Xcab Sbed,4x4, 399.7 hp.
so close
DIY intake,
Optix Gauges
4" DIY exhaust 6" Stacks,
Dynomite STG 2 SingleShot 100hp injectors,
9 pos dp Tuner,
Drill & Slotted rotors,
boost fooler,
ccv mod,
foil delete,
map modifier,
B&M deep pan,
Firestone ride right,
hutched,
sonex shift kit,
BulletProof Trans
X-Wheel
6.0 IC
6.0 Trans Cooler
siloped is offline
post #4 of 49 Old 10-05-2008, 11:11 AM Thread Starter
cchase's Avatar
I am not replacing the gaskets, they are fine, just adding the studs, so i dont think I have to pull the whole head off.
but at work I drive
7 Duramaxes
NO CUMMINS.....
cchase is offline
post #5 of 49 Old 10-05-2008, 11:24 AM
siloped's Avatar
Still, isn't it tight near the rear of the motor?
so close
DIY intake,
Optix Gauges
9 pos dp Tuner,
boost fooler,
ccv mod,
foil delete,
map modifier,
B&M deep pan,
hutched,
sonex shift kit,
BulletProof Trans
X-Wheel
6.0 IC
6.0 Trans Cooler
siloped is offline
post #6 of 49 Old 10-05-2008, 11:28 AM Thread Starter
cchase's Avatar
yeah its pretty tight. but i had planed on taking the whole front clip off, but i dont know if it will give me enough access.
but at work I drive
7 Duramaxes
NO CUMMINS.....
cchase is offline
post #7 of 49 Old 10-05-2008, 11:32 AM
siloped's Avatar
Keep posted with how the job goes. If its not bad, I probly won't put mine in the shop when the time comes.
Good Luck
so close
DIY intake,
Optix Gauges
9 pos dp Tuner,
boost fooler,
ccv mod,
foil delete,
map modifier,
B&M deep pan,
hutched,
sonex shift kit,
BulletProof Trans
X-Wheel
6.0 IC
6.0 Trans Cooler
siloped is offline
post #8 of 49 Old 10-05-2008, 11:34 AM Thread Starter
cchase's Avatar
Yeah if i do it, i will try and take some pictures, but I always get caught up in doing stuff and forget. I have to get it done now or wait till spring because i cant have it down over the winter, im still going to attemp to plow with her.
but at work I drive
7 Duramaxes
NO CUMMINS.....
cchase is offline
post #9 of 49 Old 10-05-2008, 02:48 PM
Deputydog's Avatar
Injectors have to come out, but yet if you do them one at a time, it can be done in the truck.
2002 F350 Crewcab Lariat 4X4 SRW
626 HP, soon to be 750+ HP on fuel only
Deputydog is offline
post #10 of 49 Old 10-05-2008, 03:09 PM Thread Starter
cchase's Avatar
with removing injectors, if I just take one injector out, do the studs around it, can i just put that injector back and move to the next. or do i have to take them all out and drain the cylinders?
but at work I drive
7 Duramaxes
NO CUMMINS.....
cchase is offline
