500 hp budget build
okay well heres my goal i want 500 hp single turbo with no other power adders like nitrous propane or water injection. this truck is also my daily driver so it has to be streetable. what parts do you guys suggest will get me there like what turbos and injectors. i already know ill will need a stout tranny im workin on that right now.whats is the best way to reach this goal stayin a on reasonable budget.
anybody? what injectors? would a stock hpop pump support this much power? would a garret bb turbo support this power level? h2e seem a bit pricey
My siggy would do it on nitrous. It'll do it with a modded H2E no problem though.
Based upon your signature here is what you'll need.
Transmission 230-250 cc hybrid injectors 66/17, 66/19, or 71/19 modded h2e Fuel system of some sort. That's really all you'll need, but many recommend pushrods, valve springs, headstuds at that level. Other things will make for a better driving experience like a bigger intercooler, water injection etc... |
so a garret bb wouldnt work
Not unless you want your EGT's so high you have to run water to keep them down anytime you get on it! This is for 500 RWHP on fuel.
I would want head studs above 400 ponies for sure!!!
NCH |
plus one for the headstuds , injectors, and turbo stated above, and some good custom tuning should get you close, but as far as a budget , its not gonna be cheap
I agree with everyone stated, like Marty said the gt38 wont keep cool enough without some drugs. you would need headstuds too
I did 480 RWHP on the dyno last week.. I think the Garrett is maxed out so a Modded H2E or other larger turbo would be needed. I think if I do the foil delete, I might bump 500 though
Garrett GTP38R turbo Casserly hybrid injectors dual HPOP's BTS Tranny Full fuel system |
