stock turbo longevity ? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-15-2014, 11:16 AM Thread Starter
blue99stroker's Avatar
Quoted: 270 Post(s)
I just recently got rid of the ebpv valve and now im consistently hitting 35 psi on stock injectors with low egts.
i want to make the switch to 160/30's here soon.
if im already at 35 psi, will the stock turbo last very long with stage 1's?
if i have to i will request the tuner keep it below 40 psi, which is still a lot on the stock turbo.
thanks guys
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #2 of 5 Old 01-15-2014, 11:29 AM
CSIPSD's Avatar
Its less about boost and more about the boost/backpressure ratio...
Get a back pressure gauge, if your seeing 50-60psi back pressure to 30psi boost it wont last long, if your seeing 30psi with 40-50 psi back pressure then it will last longer. Its the side loading on the bushings that kills them...
I run 55psi boost to 60-65psi drive pressure on my H2e... It stays 1 to 1 up to about 40 psi.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
The Following User Says Thank You to CSIPSD For This Useful Post:
blue99stroker (01-15-2014)
post #3 of 5 Old 01-15-2014, 02:08 PM
PSD POWER007's Avatar
Quoted: 8 Post(s)
Send a message via AIM to PSD POWER007
With the WW2 on my stocker, I hit 33psi with about 38-40lbs of back pressure according to my Insight.
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, DP-Tuner F6 Live tuned, 05 Harley's w/ HID conversion, Edge Insight CS, Dieselsite BRV & coolant filter, Factory 20" wheels, RiffRaff boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #4 of 5 Old 01-15-2014, 02:40 PM
79 toy's Avatar
Will Your insight read drive pressure?
79 toy is offline
post #5 of 5 Old 01-15-2014, 03:37 PM Thread Starter
Quoted: 270 Post(s)
ok thanks guys.
i really appreciate all the help.
the truck runs really good now, no smoke at all even if i floor it on 140, egts never get above 1100 anymore.
