what would i need to run 175cc/80% or 200cc/80% injectors - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-15-2014, 01:16 AM Thread Starter
ZackMicF's Avatar
Quoted: 29 Post(s)
im just curious, I was thinking about a new wish list for after this deployment, I was wondering what kind of HP would I be getting out of this 2 injectors all tuned up right and what would it take to run these?
obviously I wouldn't be running them together, im just wondering if get the 175 if later ill regret not getting the 200s for an extra couple 100 bucks,
I was thinking about running the garret 38r with this setup
what would be the price range on all this?
I was looking at the P.I.S injectors
performanceinjectionsystems.com
ZackMicF is offline
post #2 of 7 Old 01-15-2014, 01:37 AM
blue99stroker's Avatar
Quoted: 249 Post(s)
well the 200/80's are hybrids, would require less high pressure oil.
you would need a regulated return fuel system for either injector choice, and most likely an upgraded fuel pump.
38r with a billet wheel would work.
can look at nolimits brute66 as well. little cheaper
and probably a built trans as well
400-450 hp probably.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #3 of 7 Old 01-15-2014, 03:35 AM Thread Starter
ZackMicF's Avatar
Quoted: 29 Post(s)
well I got the built trans already about 8,ooo miles ago, thing is amazing compared to before, with bigger cooler w/ electric fan, new 6 stud torque convertor, HD rebuilt kit, some new gears, some other little mods, new pump, transgo shift kit and im planning on getting a AFE deep pan when I got to change the fluid next go around and it should be more then good,
so one the hybrids I could run the stock HPOP?
I was going to get the 189 dollar riff raff fuel return regulator system, would that work fine?
what fuel pump should I be looking at?
ZackMicF is offline
post #4 of 7 Old 01-15-2014, 05:04 AM
PSD POWER007's Avatar
Quoted: 8 Post(s)
Send a message via AIM to PSD POWER007
My HP goal was 400-425 and I went with the PIS 175/80's with my 38r w/WW2. Can't wait to get the injectors here and get up and running.
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, DP-Tuner F6 Live tuned, 05 Harley's w/ HID conversion, Edge Insight CS, Dieselsite BRV & coolant filter, Factory 20" wheels, RiffRaff boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #5 of 7 Old 01-15-2014, 05:44 AM
03ranger30's Avatar
That's probably the setup I am going to run eventually, minus the 38r. I am just using a stock turbo with a WW2.
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #6 of 7 Old 01-15-2014, 06:54 AM
CSIPSD's Avatar
You dont need a regulated return with 200's or 175's... You need a completely functional factory fuel system capable of delivering 60psi+ of fuel pressure at WOT...
If your dropping fuel pressure at WOT, then drop the tank and do some intank mods.
A regulated return doesn't give you any more volume, it simply allows better flow thru the head, that's the beauty of the Riffraff system, it cheaply solves the same issue the more expensive ones do.
Talk to Tim about your goal, I would say a set of 200's and a Brute 66 would be a very slick set up without breaking the bank!
400-425hp or more.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #7 of 7 Old 01-15-2014, 12:11 PM
Quoted: 249 Post(s)
i knew csipsd would come help.
you have first hand experience in this area.
