Stage 3 water/meth kit
I can get a stage 3 water/meth kit, barely used for next to nothing.
The question is, how safe is this to run and it it worth it? and what kind of power can i expect? I didnt plan on running any drugs for awhile but its a great price. |
Run straight water and its great for your truck!
If you have to run meth, I would recommend methanol you can buy from just about any race shop and keep the mix to 20% or so. Others have run upwards of 50/50 and seen some power increase but I'm not a fan of it. I think most people would agree you can get around 40 rwhp out of meth. At least that's what I've seen on other peoples dyno runs. I'm a big fan of water (only) injection. Its actually a good thing for your truck. |
buy it... you'll need it later for cooling.
I run straight distilled water from the store. |
Whats the normal price for a kit like this ?
about 900 bucks
anyone else on water.meth?
can i just run water with the setup? |
i run it man and havent had an issue, i never mix more than 50/50, usually i just run 0 degree washer fluis which is like 15 percent meth
ive heard a few horror stories about hydro locking the motor after parking on a hill or something to that effect but i bought the check valve they have to keep fom having that headache |
the water meth kits are awesome, im running it on mine. im running straight water and it keeps me about 300+ degrees cooler but im running a modified stage 3 im helping snow performance with. If you plan on hauling allot or running it a little hard its great. you can run Lp with it on straight water if you want as well. when i had the Superchips Lp system on i did not see higher egt's then 1150 or 1200 at the manifold, but in fairness i have allot of supporting mods.
Good luck |
thats the meth ratio on washer fluid
+20 - 7% methanol 0 - 23% methanol -10 - 28% methanol -20 - 35% methanol -25 - 38% methanol -50 - 62% methanol |
Great thanks stump, so just make sure I put in the check valve! did you notice any power gains?
