Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 10-02-2008, 06:53 AM
j_cyrus3 j_cyrus3 is offline
Boost tube for gauge
I can't get the damn thing to stay in... Every time my truck gets to about 32lb of boost the tube pops off... I've tried to put black tape on the tube and the boost fooler thing, but it just wont stay in... Any suggestions?
Old 10-02-2008, 07:09 AM
zeuss zeuss is offline
If you are talking about where you tie into the line for the map sensor, I put a brass T with barbed fittings in the map line and then a screw in fitting with the right feroul for the plastic line that goes to the gauge. I haven't had any problem. I also did put hose clamps on the lines for the barbed fittings. Let me know if you want a picture. Good luck
Old 10-02-2008, 07:10 AM
dsnodd dsnodd is offline
Tighten down the nut.
If that doesn't work maybe you need a new little brass collet thingy(I don't know what there called) you can get them at any hardware store.
Old 10-02-2008, 07:11 AM
please post a picture... Thanks.
Old 10-02-2008, 07:14 AM
Also, while im talking about this... How can I get the SES light to stop coming on? I can't get the thing adjusted properly, any tips on that?
Old 10-02-2008, 07:45 AM
driximus driximus is offline
for overboost I have the ITP overboost Annihilator
Old 10-02-2008, 08:25 AM
CSIPSD CSIPSD is offline
You should not have to ajust the ITP overboost regulator...
Sounds like you used the plastic fitting that came with the gauges... you need to get a brass T with 1/4" barbed fittings and a 1/8" compression fitting on one.
Old 10-02-2008, 08:28 AM
ill get pics of what I have... it's black and has a knob, with 3 fittings, 2 brass fittings on the sides and a brass nut type thing where the boost tube goes in.
Old 10-02-2008, 08:29 AM
Sounds like you did not put the compression ferrel on there.
Old 10-02-2008, 03:10 PM
NCHornet NCHornet is offline
Powerstroke Techie
Yeah that wil do it!!!
