jet engine! - Ford Powerstroke Diesel Forum
post #1 of 21 Old 01-14-2014, 12:02 PM Thread Starter
StrokinAlaska's Avatar
jet engine!
So we have a customer that came into the shop a few weeks ago, and his truck (00 f350 with the 7.3l) sounds like a jet while warming up after starting. It was the greatest sound ever!
My question is what is needed to get that sound. I have a 99 f350 7.3l with a AFE intake, WW2, 4" magna flow down pipe into a 5" straight pipe exhaust and up into dual 8" stacks, and a TS-6Position Chip. I really would love to get that sound as its badass. I can get it when my truck is in the 100hp and 140hp setting only
Thanks!
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
TS-Performance 6 Position Chip
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
(2) 52" VisionX Xmitter Led bars
VisionX Cannon 4.7"
VisionX Cannon 6.7"
(2) 42" RaceSport Led bar
(4) VisionX Solo Soltice
(4) RaceSport Duallys
Hids
Alpine INE-S920HD
20 Speaker Rockford Fosgate Stereo System
3 Bulk Packs of Ballistic
Smoked Cab Lights, Fender Lights, SwitchBack Leds
Tint
2.8" Front leveling kit
StrokinAlaska is offline
post #2 of 21 Old 01-14-2014, 12:08 PM
CSIPSD's Avatar
Sounds like his Exhaust Back Pressure Valve is closed.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 21 Old 01-14-2014, 12:12 PM Thread Starter
Haha so its not a good thing then is what that means
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
post #4 of 21 Old 01-14-2014, 01:37 PM
Quoted: 176 Post(s)
Feedback Score: 3 reviews
Because the engine doesn't warm-up easily, the EPBV is designed to cause a restriction making the engine "work harder" and produce Heat earlier. It's actually supposed to do that when it's cold.
I don't know why people object to that noise, I like it too!
NoRalPh is offline
post #5 of 21 Old 01-14-2014, 01:52 PM Thread Starter
Its a sound that just makes me smile ear to ear ha.
My truck likes to 'wet stack' when its cold out. Is there any way around that, my neighbors arent too fond of the noise it makes at 8am 6 days a week lol. Also my heater only works on defrost, I've read around the forum and seen how to check it outside under the hood and checking the vacuum lines but still am lost on it :/
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
post #6 of 21 Old 01-14-2014, 01:59 PM
blue99stroker's Avatar
Quoted: 283 Post(s)
yep what csipsd said
it just means the truck is cold trying to warm itself up.
there is a butterfly valve on the exhaust housing of the turbo.
it closes to create load to warm the engine up.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #7 of 21 Old 01-14-2014, 02:03 PM Thread Starter
What else can i do to get more turbo sound. I read online some guys pull the heat shielding off the up-pipes and bellow-pipes and the hood liner as simple solutions. I've looked into changing out my piping and doing a techicooler from banks
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
post #8 of 21 Old 01-14-2014, 02:36 PM
Justin@DP-Tuner's Avatar
Quoted: 63 Post(s)
As others have stated, it's the EBPV and it is completely normal when cold if the EBPV system is operating correctly. Most get rid of it because of it's potential issues (mainly oil leaks and sticking). I enjoyed the sound of it too when I had mine functioning. However, at 6AM my neighbors did not
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #9 of 21 Old 01-14-2014, 02:45 PM
CSIPSD's Avatar
You can remove the insulation from the hot side of the IC...
A Banks IC will not do anything sound wise...
I cant understand why people want to listen to that crap for hours on end, must be just old...
Here is my truck with no hood insulation, no firewall insulation...
Joe
CSIPSD is offline
post #10 of 21 Old 01-14-2014, 04:38 PM
03ranger30's Avatar
Damn Joe your truck sounds good. Mine does this weird thing where it sounds like it's opening and closing very rapidly, making a loping sound. It's annoying as hell.
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
