coolant drain plug stuck - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-13-2014, 05:30 PM Thread Starter
keep's Avatar
Garage
Question coolant drain plug stuck
the block drain plug on the passenger side above the starter wont budge for me. are there any tricks that could help me get this out? heat cycle? wrench combination?
I currently have it soaking overnight with some pb blaster, but could use any tricks anyone has as I would love to avoid pulling that starter to get the darn thing out so i can finish my coolant flush.
Thanks!
keep is offline
post #2 of 3 Old 01-14-2014, 07:05 AM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
Frankly, I wouldn't worry about it...
It's a nice thing to do, removing the plugs, to get a through flush, but Hardly necessary
Refill it with distilled water and drive it around the block. You'd need a chemistry lab to measure the difference in remaining old coolant
NoRalPh is offline
post #3 of 3 Old 01-14-2014, 03:27 PM
Christ Follower
7.3Excursion4x4's Avatar
Quoted: 14 Post(s)
Mine was a PITA to get out as well. When I put it back together, I used these:
This one on the passenger side behind the starter because of clearance.
This one on the drivers side
So much easier now to flush
403,000
PHP Hydra
Stage 1 Full Force Injectors
MBRP 4" Turbo Back
F-650 Dash w/EV2 Gauges
CT Performance Suspension
Firestone Ride Rite
DieselSite 4R100, Adrenaline HPOP, WW2
DieselSite Engine & Intercooler Boot Kit
DieselSite Tranny & Coolant Filters
SSBC V8 kit with EBC Rotors
NCHornet's CCV, Swamps IDM
Derale Atomic Cool
6.0 Trans Cooler, Cat ELC Coolant
Mag Hytec tranny pan
7.3Excursion4x4 is offline
