Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 09-30-2008, 05:48 PM
powerstrokes for life powerstrokes for life is offline
mods for 01 powerstroke
ive got a 01 powerstroke with the hypertech we are running low 15s. But, that is not good enough could yall tell me a package that could help me get into the low 14s.
Old 09-30-2008, 05:58 PM
DKR DKR is offline
<--Pro Cooler Racer
I broke this off into its own thread for you to get some better visibilty by the 7.3 guys.
Old 09-30-2008, 06:00 PM
thesmokinstroke02 thesmokinstroke02 is offline
go tony wildman, stage IIs, build the tranny, and do some other small stuff and that shold get you where you want i think.
Old 09-30-2008, 06:01 PM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
how about this: Stealth Automotive. Stealth Performance Bundle
its a full package you can build with the best stuff for the 7.3L
intake, exhaust, gauges, and a custom tuned chip....
def way better than that crappy generic tunes your running
-Raul
for got to add that if your looking to do more than just that go with a upgarded turbo like the turbonetics BB unit, upgraded injectors... the size of injectors would depend on what you want to do....
Old 09-30-2008, 06:04 PM
oh yah would like to add what kind of dyno were you running on when you pulled those numbers...
no way you would pull those numbers with just the Hypertech....
with just the HT i woudl guess you to be at 290-310hp to the wheels.... and barely at 600 torque
Old 10-01-2008, 07:16 AM
NCHornet NCHornet is offline
Powerstroke Techie
The 01 has the mecjanical diode, so if you haven't had the tranny die on you already you are very lucky!! The 7.3 has a lot of hidden power as it was severely detuned because of the 4r100 trans. But you need to do things right. My preferred list and order is
Gauges
Intake
Exhaust - just a straight muffler, no need for a 4" system
Trans supports
Tunes from either DP or TW
PM me with any ?
NCH
Old 10-01-2008, 09:01 AM
CSIPSD CSIPSD is offline
You will not put down more then 300-320 without Turbo, injector or drugs...
