6.0 IC on 7.3? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-12-2014, 10:58 AM Thread Starter
Ford710's Avatar
6.0 IC on 7.3?
My friend offered me his 6.0 IC for free. Do these make a difference on the 7.3s? If so, what? And what do I need to hook it up?
03 f250 7.3l 4x4
Cold air
Diablo chip
Air dog 150 extra filter
5" exhaust 7" tip
24" RBP rims 36.5 Pirellis
07 Harley front
07 Harley interior
'10 tailgate, lights, mirrors, rear window
2 kicker 12" shallow mounts
Kicker amp
Ford710 is offline
post #2 of 5 Old 01-12-2014, 11:42 AM
Gene's Avatar
Quoted: 3 Post(s)
I'm running one on mine. Helps keep EGT's down when towing. I needed to change out my boots to run the intercooler. The diameters between the 7.3's and 6.0's outlets are different.
Please note that the 6.0 flows in the opposite direction as the 7.3, so you will want to really clean it out good before putting it in a 7.3.
Gene
2001 F350 Crew Cab Long Bed 4x4 6 speed
PHP Hydra, 4 inch MBRP Exhaust, GTP38R, FRx, DIY Exhaust Brake, T500 HPOP, Hutch/Harpoon,
6-liter Intercooler, 6637, DIY Coolant Filter, CCV Mod
Gene is offline
post #3 of 5 Old 01-12-2014, 11:50 AM Thread Starter
Ford710's Avatar
Awesome thanks, how do you like your wicked wheel?
03 f250 7.3l 4x4
Cold air
Diablo chip
5" exhaust 7" tip
07 Harley front
07 Harley interior
Kicker amp
Ford710 is offline
post #4 of 5 Old 01-12-2014, 04:20 PM
Gene's Avatar
Quoted: 3 Post(s)
It makes a nice noise, other than that, I don't see much real benefit. I've heard that it takes away top end boost, but gives more bottom end boost.
I put it on during a turbo rebuild because I needed a new compressor wheel due to some scarring on my original wheel.
Gene
Gene is offline
post #5 of 5 Old 01-12-2014, 05:00 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
6.0 intercooler drops egts 50-100 degrees.
dieselsite and riffraff sell the intercooler boots needed when you do the swap.
a newer billet wheel is much better than the original cast 10 blade wheel
i can say this because i have ran both and the new billet wheels are huge improvement
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
