New injectors - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-11-2014, 06:00 PM Thread Starter
Ford710's Avatar
New injectors
Replacing all 8 injectors on my truck, any mod suggestions or ideas I could do while everything is off.? That's cheap
03 f250 7.3l 4x4
Cold air
Diablo chip
Air dog 150 extra filter
5" exhaust 7" tip
24" RBP rims 36.5 Pirellis
07 Harley front
07 Harley interior
'10 tailgate, lights, mirrors, rear window
2 kicker 12" shallow mounts
Kicker amp
Ford710 is offline
post #2 of 6 Old 01-11-2014, 09:23 PM
Injector cups while your there. Had a buddy put new injectors in his truck and 5k later had to pull them back out later to do cups.
2000 f350 single wheel, zf6, 4 inch exhaust muffler delete, sb cold air intake, wicked wheel 2, Ts performance chip, international bellowed up pipes, 8 inch lift, 37 inch tires. Sold
2006 f350 ccsb, 4 inch turbo back exhaust, sct tuner.
Southernways is offline
post #3 of 6 Old 01-12-2014, 12:23 AM
Thuglike's Avatar
If there is no coolant in the cylinder..there is no reason to do the cups. Now, if only 1 cylinder has coolant in there while your clearing it..do all 8. But if it's free of coolant, leave it alone. (My opinon)
It's just dumb luck when the cup(s) go bad. Replace them when you have to.
Thuglike is offline
post #4 of 6 Old 01-12-2014, 04:53 AM
Im replacing my injectors this week with Swamps 250/200's. Doing studs and valve springs while Im there. Just a suggestion.
wiley79 is offline
post #5 of 6 Old 01-12-2014, 11:49 AM Thread Starter
Ford710's Avatar
I was gonna do 160cc from performance injection systems, I saw they ran about the same price as the stock ones. This was an unexpected fix so I'm limited on what I can spend
03 f250 7.3l 4x4
Cold air
Diablo chip
5" exhaust 7" tip
07 Harley front
07 Harley interior
Kicker amp
Ford710 is offline
post #6 of 6 Old 01-12-2014, 01:36 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Check your glowplugs while your there... maybe update to the newer UVCH with better clips or do the 50 cent mod.
Not much inside the engine would be considered "cheap"
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
