Pillar Gauges vs CTS?? - Ford Powerstroke Diesel Forum
post #1 of 22 Old 01-10-2014, 05:50 PM Thread Starter
Msp079's Avatar
Quoted: 52 Post(s)
Question Pillar Gauges vs CTS??
Hi All,
Looking to put some gauges in the truck but before I do, what would you guys do?? Pillar gauges or the CTS?
Thanks
2005 F350 Harley Davidson Edition CCSB SOLD!!!
Icon Vehicle Dynamics 4.5" stage 4 lift, 37x13.5R20 Toyo Open Country M/T, 20x10 Fuel Throttle wheels, ARP headstuds, EGR delete, MBRP 5" powdercoated turbo back exhaust, wicked wheel, Blue spring mod, Mishimoto Radiator, oil cooler, stand tubes and dummy plugs, Sinister Diesel coolant filter, 6.4 banjo, Air Raid air filter, SCT X4 tuner with tunes from Innovative Diesel, EGT, HPOP, fuel pressure A-pillar gauge pod
Msp079 is offline
post #2 of 22 Old 01-10-2014, 05:58 PM
Joel's Avatar
Quoted: 10 Post(s)
Both is the route I took
But seriously, its your truck. Do you like the modern screen look or do you like the undeniably classic performance oriented look of gauges?
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 22 Old 01-10-2014, 05:59 PM
Raul@Stealth Automotive's Avatar
you cant go wrong with either of them.. for a list of things that the insight can read on a 7.3L you can go here: Edge Insight Gauges
if it were me i would go with the CTS...
Raul@Stealth Automotive is offline
post #4 of 22 Old 01-10-2014, 06:07 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
The cts for me was the way to go. Plus it can read trouble codes. Plus it will remind you when to perform maintenance. plus it will help you with fuel mileage via the fuel coach. And you can add multiple different thing s onto. (egt sensor,turbo timer,back up camera etc.)
Plus its all plug n play. Super easy and a big bang for the buck.
With that said I still want a few pillar gauges just cause the look cool. But the Edge cts is imo were you should start out at.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 22 Old 01-10-2014, 08:01 PM Thread Starter
Msp079's Avatar
Quoted: 52 Post(s)
I got a Ts 6 chip can I just plug and play and not have to use the edge performance mods...I just want the screen for all the other stuff and use my Ts 6 chip...Is that possible? Does this plug into your PCMCIA ??
Msp079 is offline
post #6 of 22 Old 01-10-2014, 08:03 PM Thread Starter
Msp079's Avatar
Quoted: 52 Post(s)
I ment to put PCM .....my chip is in there...never used something like this CTS before.
Msp079 is offline
post #7 of 22 Old 01-10-2014, 08:17 PM
john galt's Avatar
Quoted: 1387 Post(s)
I would and have started with the cts and have the pilar in my shop awaiting gages and paint to match the interior but the cts is the biggest bang for the buck and a great place to start in my opinion.
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #8 of 22 Old 01-10-2014, 08:39 PM
kbragg430's Avatar
I bought the cts. I think its great. And yes you can use a chip (I have the hydra) in the PCM with the CTS because the CTS plugs into the OBDII port.
The CTS just gets expensive when adding stuff on like that turbo timer or actual boost gauge because of the Y-adapter needed for each new gauge, and you can only view 5 things at a time, which is a lot.
Plus I love the minimalist look over having my truck lined with gauges.
2002 F350 CCSB SRW 4X4 ~110k
4" MBRP, DIY Tymar, PHP hydra, Edge Insight CTS, 360* thrust, RR billet wheel, delete pedestal and outlet,
Napa ELC, melling 208 Lpop, 6.0 trans cooler, diy coolant filter, 203* thermostat, RR IC boots w/ plenum inserts, frx, hpx, hutch&harpoon
331 hp / 620 tq
Dynod by dynoproven 4/19/14
kbragg430 is offline
post #9 of 22 Old 01-11-2014, 02:37 PM
03ranger30's Avatar
If I am reading that correctly, it will monitor all those things listed without any modification?
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #10 of 22 Old 01-11-2014, 03:18 PM
To Many Projects
Twinjracing's Avatar
Quoted: 14 Post(s)
Originally Posted by Msp079 View Post
Hi All,
Thanks
I love my CTS in my 2012 loved my old stlye insight in my 08. And I plan on useing one in my 01 Excursion when I get money for.
17 F250 XLT CC LB SRW 4X4, Truxedo Lo Pro Cover, Spray In Bedliner, Airlift Bags, And Cobra 29LX
E99 F250 Ext LB 4X4 Terminator HPOP, Rosewood Stage 160/80, T4 Billet S366 66/74/1.10, NLTD Tunes, Custom Traction Bars, Custom Winch Bumper
71 Cutlass Supreme Dragcar, 66 GTO, And 72 Vista Cruiser
JJ
Twinjracing is offline
