Best Waste Gate Actuator? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 20 Old 01-10-2014, 04:26 PM Thread Starter
Quoted: 3 Post(s)
Im looking into a new waste gate because i know my OEM one is screwed up. Whats the best one out there? Ive seen Banks which i know is overpriced junk and Turbo Master from Dieselsite. Is there any others i should be considering?
Thanks in advance.
2000 PSD, 4in Exhaust, 6637 Intake, Zoodad, TS Canned Tunes, JWVB, Billet Wheel, FRx
ilovemy7.3 is offline
post #2 of 20 Old 01-10-2014, 04:32 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
turbomaster for sure.
the other ones are just standard waste-gates with a heavier duty spring inside so they can withstand more pressure.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is online now
post #3 of 20 Old 01-10-2014, 08:07 PM
utown_PWRstroke_smoke's Avatar
Quoted: 19 Post(s)
Garage
Turbo-master from all the reading I have done.
I just ordered one and it will be here tomorrow UPS, kinda pricey still
but looks to be built well, and if it does what dieselsite and others says it will work very well. will post up pics tomorrow if you want any
2001 F350 7.3L
| 4x4 Rcab LB | ZF 6speed
MBRP Turbo Back|Muffler Delete|TW Tunes|S&B Intake|IH Bellowed Up Pipes|ZooDad Mod|WickedWheel2|RR FRx|RR HPx|DS Turbomaster|RiffRaff OCR
6" Icon|Dual King Stabilizers|Bilstein 5100|Platinum Edition Leather Seat Conversion|35" Toyo MT|20" BMF SOTA|Custom Badges|Harley Headlights|Custom Built TireGate/Bumper|LineX|Tube Running Boards|52" Led Light Bar|Dually Led Lights
utown_PWRstroke_smoke is offline
post #4 of 20 Old 01-10-2014, 08:17 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Id say the best wastegate is no wastegate. If you unplug the red line from the waste gate it wont activate and wont let boost bleed off. Just make sure of 2 things, 1. put the red line on something like a bolt or plug it so it doesnt leak boost,and 2. have a boost gauge to read the psi because you really dont want to go over 25 psi. It defuels at 22 psi anyway but its nice to watch the gauge just in case.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #5 of 20 Old 01-10-2014, 08:21 PM
Quoted: 247 Post(s)
i thought air travels threw the wastegate into the redline which feeds to the solenoid.
the wastegate is a canister with a spring that opens at 7-8 psi (stock wastegate)
so after 7 psi it just leaks air.
post #6 of 20 Old 01-10-2014, 08:26 PM
Quoted: 19 Post(s)
Garage
that works too! ^ wouldnt do it without a boost gauge tho as said
2001 F350 7.3L
post #7 of 20 Old 01-10-2014, 08:29 PM
Chapter Director
Quoted: 5 Post(s)
Nope air(boost)travels from the red line(at the spyder) to the wastegate canister and at 5 psi it begins to move and forces the actuator open. The more boost the more it bleeds off
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #8 of 20 Old 01-10-2014, 08:39 PM
Quoted: 725 Post(s)
Yep. What he said. ^^^^
I unhooked mine too n plugged it with s bolt. Took my air compressor blow gun and put 20psi to the actuator head. I kept tightening the rod until the 20psi of air just barely cracks open the wastegate.
Corey@CNCFAB is offline
post #9 of 20 Old 01-10-2014, 09:36 PM Thread Starter
Quoted: 3 Post(s)
I have the wastegate unpluged already and gauges but i know the waste gate is broken thats why i need a new one. I think i finished it off today when i tried to tighten it
post #10 of 20 Old 01-11-2014, 12:20 AM
Quoted: 725 Post(s)
Did the spring break???
