This is what I'm thinking - Ford Powerstroke Diesel Forum
Old 09-23-2008, 05:35 PM
I want a little more hp, here is what i'm thinking
Regulated Return
Diesel Innovations - Products
Bigger fuel pump
Auto Performance Engineering - Walbro fuel pumps and more
the GSL392 model
bigger pick up line
ITP 5/8" Fuel Tank Pickup
and a
ITP 7.3L Fuel Tank / Pre-Pump Kit
and water/meth
how does that plan sound?
Old 09-23-2008, 06:52 PM
for your regulated return line why not go with itp they may cost a little more but you get what you pay for from them nothin but quality parts pus your already using there other parts there pick up tube and prepump kit
Old 09-23-2008, 07:48 PM
Go to ITP's site and get the Air Dog, and his fuel bowl delete/ complete fuel system... All SS hard lines and SS braided...
Fuel system will net you 0 extra HP... Just a better running truck and a building block for later.
Old 09-24-2008, 06:02 AM
Ok i was told to get rid of my turbo, and get a garrett i told them I liked mine. They said the garrett will make more power and last longer. hmm how can i blow mine up? so i can get a garrett? My warrenty it about up.
I found a deal on some stage 2 single shot injectors, how much boost would i be running then with my TN? would i need head studs?
Old 09-24-2008, 02:56 PM
Not a damn thing wrong with your TN... I put down 470hp with mine and it has seen 50# boost more then once...
Stage 2's and turbo I was at 36-38psi and just north of 400...
Old 09-24-2008, 02:58 PM
thats what i wanted to hear, if i'm pushing 38psi, would i need head studs?
Old 09-25-2008, 10:24 AM
I tested today, i can hit 30 so with stage 2 i should hit 37ish? i shouldn't need head studs for that i don't think
Old 09-25-2008, 03:31 PM
It is easy to install studs in the truck... it isn't hard at all... takes about 8 hours total...
