Help! LiveWire on 7.3 problems - Ford Powerstroke Diesel Forum
Old 09-22-2008, 06:13 PM
H E L P!!! I just got a new livewire and have it set to street specs. I am getting 2 codes from it. po603, and po470. what do they mean. plus my trans feels like it is slipping from first to second and feels like it is popping from second to third. any suggestions. I have a 2000 with 7.3 powerstroke
Old 09-22-2008, 06:22 PM
whos tunes are you running?
Old 09-22-2008, 06:33 PM
Im running the preloaded street and performance tunes from SCT. I havent made any changes, just hooked it up and running their preloaded setups.
Old 09-23-2008, 03:36 AM
Powerstroke Junkie
Those codes could have been in there for years!! Clear them and see what if any codes return? The 603 is the cam position sensor. Have you ever had one go out? If so that is the code from when it did. The 0470 code is the exhaust back pressure valve, could just be carbon build up or it could be a bad sensor. I cleaned mine three times before it finally went. Get the part from IH it is much cheaper!!
NCH
Old 09-23-2008, 06:38 AM
thanks I will try that with the back pressure sensor. anyone heard anything about these tunes from five star tuning. are they reputable, and are the tunes good. plus I have never had a cam shaft problem
Old 09-28-2008, 06:57 PM
I've never heard of five star tunes. There are a few places I have found that custom tune the livewire, I went with Elite because it was a friend of a friend deal. I can tell you that the pre-loaded tunes are nothing compared to the custom tunes you can get.
Old 09-29-2008, 02:18 AM
does elite have a website that you can go to and check out their tunes offered
Old 09-29-2008, 04:37 AM
Welcome to Elite Diesel Engineering i believe
