Need tuner/chip for 2 trucks - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-04-2014, 06:02 AM Thread Starter
I just purchased 2 trucks for my business from Alabama and brought them up to Ohio. The first truck is a 2001 F350 automatic with 115k that will be used as a daily driver/ work truck. This one will be used to pull a trailer with equipment on it once in awhile. The other truck is a 2001 F550 automatic with 160k that will be used strictly for work and will always be loaded. The truck will sit at abouth 13,000 pounds and will also pull a trailer on occasion. It will usually be driven by an employee who is responsible. I'm installing gauges (egt and trans temp) on the F350 but the F550 won't be getting any as he wouldn't know what to look for anyways. I installed a walker BTM and AIS intake on both trucks along with all the basic maintenance . I want to chip both trucks to open them up a little bit and probably won't do any other mods to them unless it's something simple that you guys recomend. After doing some research I figured the PHP Phoenix chip was the way to go for $275. It turns out they don't have them in stock and won't for a long time. They're trying to sell me the Hydro for $400 plus but that's a big hit for both trucks. I don't even think I want something adjustable for the f550 as it will always probably be in the same mode. They said they can reflash the PCM for $150 but I'm not sure how that will effect diagnostics if I ever have a problem with the truck. I like the ideal of turning the chip off if I ever have a problem. If they flash the PCM, I won't even be able to remove them. What do you guys think is best for me and the best bang for the buck? Any recomendations would be appreciated. Thanks!
giannid is offline
post #2 of 4 Old 01-04-2014, 06:11 AM
blue99stroker's Avatar
Quoted: 283 Post(s)
you've got all the basic mods done plus gauges which is great
as long as the dealer doesnt reflash your computer flashing the pcm is fine.
check out gearhead or no limit tuning, they are pretty decently priced.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #3 of 4 Old 01-06-2014, 10:51 AM
CSIPSD's Avatar
Check out this guy...
POWER-STRUCK, osgood indiana, performance tuning
I've not used them, but have had many conversations with him over the years. Sounds like his chip is just want your looking for!
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #4 of 4 Old 01-16-2014, 06:38 PM
Look at dp tuner infinite, can run multiple trucks off of it. Pay money for each vin
Sent from AutoGuide.com App
treemover is offline
