Billet Wheel Results? - Ford Powerstroke Diesel Forum
post #1 of 49 Old 01-03-2014, 01:18 PM Thread Starter
Quoted: 3 Post(s)
Hello all, i recently installed a billet wheel along with a FRx in my truck. After a short test drive i noticed a sort of knocking/grinding noise and thought oh crap the wheel is hitting the compressor housing. (it was not doing that when i first installed it) Just as i suspected the wheel was just barely scraping the housing (about every ten turns i could here and feel it scrape) so i called Clay at Riff Raff and he was very helpful in returning my many calls quickly. His suggestion was to tighten up the wheel a few more inch pounds so that is exactly what i did. After i reinstalled the turbo and took it for another drive everything sounded and looked good. I did everything according to the instructions, i did NOT use an impact to remove the wheel. After my last drive i noticed a weird smell coming from what i think is under the hood. It smells like burn oil or something to that nature. Is this common after a taking the turbo off and on again? I know this is long but i also was not that impressed with the results. My boost seems to be about the same, maybe a little bit higher, and my egt's seem to be higher ( or about the same) as well? Im not sure if i was expecting to much or if i did something wrong? I am just afraid that i have screwed something up. I have been checking for leaks after every time i drive it and i have yet to discover any. (no soot around the downpipe, firewall, etc.) I may just be overreacting and my expectations may have been to much? If anyone has any guesses please let me know.
2000 PSD, 4in Exhaust, 6637 Intake, Zoodad, TS Canned Tunes, JWVB, Billet Wheel, FRx
ilovemy7.3 is offline
post #2 of 49 Old 01-03-2014, 01:47 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
you should see a big difference in performance and egts.
are you getting lots of shaft play from your turbo?
might consider rebuilding your turbo, before it chews up your new billet wheel.
i have used an impact to swap wheels. i also did it with a ratchet on my buddies truck.
did you get the ccv hooked up correctly?
did you over tighten the turbo to the pedestal?
how about the clamp on the back of the turbo? it can be difficult to get it lined up straight sometimes.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #3 of 49 Old 01-03-2014, 02:10 PM Thread Starter
Quoted: 3 Post(s)
I know the up-pipe collector clamp is on good because that is the first thing I made sure was hooked up properly.
There was no In and out play on the shaft, a little side to side.
And yes the ccv is hooked up
post #4 of 49 Old 01-03-2014, 02:13 PM Thread Starter
Quoted: 3 Post(s)
And I torques the pedestal to 20 ft/lbs instead of 18 because my torque wretch didn't go that low
post #5 of 49 Old 01-03-2014, 02:59 PM
Quoted: 249 Post(s)
i over tightened my pedestal when i removed it last (oops) and it restricted oil flow to the turbo. fixed that. everything was fine after all was said and done.
did you remember to hook up the ebpv rod?
post #6 of 49 Old 01-03-2014, 03:03 PM Thread Starter
Quoted: 3 Post(s)
Should I losen and retorque the pedestal?
And yes the ebpv rod is hooked up
post #7 of 49 Old 01-03-2014, 04:39 PM
Quoted: 249 Post(s)
i dont think thats your issue, just throwing it out there.
how did you remove the wastegate?
did you remove it completely or just loosen the two 10mm nuts that hold it to the compressor housing?
might try tightening the wastegate
do you need/run a boost fooler? i dont know if standard ts tunes prevent it from defueling
post #8 of 49 Old 01-03-2014, 04:52 PM
machinestheman's Avatar
I would yank it and rebuild it rebuild kits are cheap enough and if nothing else it's worth the peace of mind I lost a set of bearings and now I have a wicked wheel mantle piece
01 f 450 6sp 4WD
DIY intake with prefilter, CCV mod, IAH delete, Granatelli big G monitor with electronic fuel pressure sender, sinister diesel coolant filter, muffler delete and hollow cat, IH bellowed up pipes, polished intake spyder, 203 thermostat, billet fpr housing, hpx hard line.
machinestheman is offline
post #9 of 49 Old 01-03-2014, 04:59 PM Thread Starter
Quoted: 3 Post(s)
I completely removed the wastegate, i took off the c-clip and the two 10mm nuts. I do run it with the red line to the wastegate disconnected and i not have a boost fooler. Im going to check my intercooler boots one more time to make sure that they are not leaking. Could leaking intercooler boots cause higher egt's?
post #10 of 49 Old 01-03-2014, 05:39 PM
Quoted: 249 Post(s)
oh ya.
a intercooler boot not on properly kills performance big time.
less boost and higher egts.
my friend had two of his loose and he could only get 10 psi max and his egts were ridiculous.
until i fixed it will eating dinner at in n out
