Hutch mod fuel filter? - Ford Powerstroke Diesel Forum
post #1 of 21 Old 01-02-2014, 08:24 PM Thread Starter
Quoted: 14 Post(s)
What do you guys recommend for a fuel filter when I do the hutch mod? Guzzle commented that the Racor he used wasn't up to the task and mentioned Dahl, but I didn't find much in the way of a complete Dahl filter/mount setup.
Am I better off just buying the whole kit from Strictly Diesel? They list 15ft of fuel hose. I thought the fuel pump was located down on the frame near the fuel tank. What's all that fuel line for?
ttyR2 is offline
post #2 of 21 Old 01-03-2014, 04:23 AM
broncomitch's Avatar
The hose runs to the pump cus you can't reuse the stock line...but mainly there just trying to justify there price.
Get this.
WVO Bio Diesel Mount Base for HD Fram PS3712 Fuel Filter Water Separator | eBay
And get a lift pump then Get everything else at your local hose supply..
You can also get mounts like that at yours local farm supply
L99 f250 7.3 powerstroke,
L99 hybrid turbo,
Built transmission,
TS, 6 position chip,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
FPR alum housing with black spring,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
06 axles and suspension,
09 steering box,
015 spring swap and shackle flip.
Saginaw PSP conversion,
016 front bumper,
Autometer&Torque app for gauges,
71 early bronco "rock crawler" 351w,c6,strong box,np205,1tons, 44"tires, ect ect.
broncomitch is offline
The Following User Says Thank You to broncomitch For This Useful Post:
mezmerizz (02-24-2015)
post #3 of 21 Old 01-03-2014, 04:38 AM
Quoted: 16 Post(s)
Feedback Score: 3 reviews
I got the kit from strictly and i'm glad i did. It had everything i needed and i didn't have to track down anything. I had about 8' of fuel line left to use on something else.
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #4 of 21 Old 01-03-2014, 07:11 AM
03ranger30's Avatar
I've read you don't need to use a pre pump filter. The DieselTechRon guy on youtube says he has done quite a few of them and haven't used a fuel filter without a problem.
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #5 of 21 Old 01-03-2014, 07:42 AM
Quoted: 16 Post(s)
You don't NEED a oil filter to make a motor run but i wouldn't advise not using one
post #6 of 21 Old 01-03-2014, 08:48 AM
If the mixer/filters are getting dirty and clogged then guess what?
All that crap is going through your fuel pump till it gets to your main filter then to the injectors.
Russian roulette there buddy
L99 hybrid turbo,
Built transmission,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
09 steering box,
016 front bumper,
post #7 of 21 Old 01-03-2014, 09:29 AM
russtwentyfour's Avatar
I did hutch and harpoon mod, put in carter lift pump with no filters before stock pump. Cost me my stock pump. So I got on eBay and got a dual filter setup cheap, run a water separator and 3 micron filter prepump now and ally good for over a year now. About to get a post pump filter and do a regulated return this winter.
E99 F350 Ext. cab Long bed, single wheel 2x4
Riff Raff 6637 intake, FRX and HPX,
Dieselsite boostfooler, factory tech valvebody, filter system,
Local custom trans build - BTS in near future,
Derale cooling pan and trans cooler,
Mbrp 4" turbo back
Ts 6 pos chip - TW tunes coming soon,
Guzzles hutch and harpoon mod with lift pump and racor filters
Ww2
Blank pedestal with moded exhaust port
Afe rear end cover
Callahan drilled and slotted rotors front and rear
russtwentyfour is offline
post #8 of 21 Old 01-03-2014, 12:09 PM
Justin@DP-Tuner's Avatar
Quoted: 50 Post(s)
It isn't recommended to run that kind of restriction pre-pump since fuel pumps are not built to suck. The water separator is a good idea, but you may want to think about moving the pre-pump filter to post-pump so your pump can live a longer life.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #9 of 21 Old 01-03-2014, 12:36 PM
Quoted: 27 Post(s)
I might just be confused but dont you want the filter in front of the pump to protect it? Cant he just get a filter that isnt 3 microns....Otherwise whats the point? your filtering fuel twice before it hit's the heads, and never before it hits the pump...
2000 F-250 XCLB 4x4 6 Speed, PIS 175/80's, ARP's, 910's, Irate Fuel, 6637, GTP38R, 4" turbo back, Hydra PHP tuned, International Up-pipes, ISSPRO Boost, EGT, HPOP and Fuel Pressure gauges. SB Clutch. MB Diesel HPOP stage 2.
CarportMechanic is offline
post #10 of 21 Old 01-03-2014, 12:55 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
just make sure the filter is rated for suction.
i really like strictly's kit too, it is on the the to do list probably when injectors get replaced.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
The Following User Says Thank You to blue99stroker For This Useful Post:
63wagon (01-31-2014)
